Question about Stanley Proto Measuring Tools & Sensors
I have a new Stanley Jumpfit 1000 set it up charge for the first time and the area light tool won't cut off. I cut it off manually several times but it keeps cutting back on. What do I do to make it stop
6ya staff
SOURCE:
Anonymous
  • 231 Answers
SOURCE: 89 GMC Sierra problem
there is an ignition module located rite beside the distributor cap on the distributor base these are well known for getting weak and heating up thus causing your engine to stall.
Posted on Oct 15, 2008
Anonymous
SOURCE: dash, running lights, radio..on and off
Something similar happened to my 2005. the gauges went crazy! stopped half way or dropped completely down. Like the fuel indicator, speedometer, tach. While I never lost the radio or headlights, I did lose my dashboard lights--pretty creepy at night. My husband did some online digging and found the problem. In the dashboard gauge set-up there is a poor solder on one of the electronic components. He took the gauge center off, popped it open, found the crappy solder, fixed it, put it back in and it has worked fine ever since!!!
the ****--Ford knows about this faulty soldering and since it doesn\'t happen to ALL of the cars--just a select few(even more models we found out later)--they won\'t do a recall. Even if you take it to a dealership for them to fix, odds are they could replace it with an entire unit with the same problem. Your best bet is to fix the bad solder yourself or find someone who can.
Posted on Mar 11, 2009
Jesse
  • 90 Answers
SOURCE: My car cuts off at times right after it is cranked. At other times when stopped at a stop light but starts back up. Also, when driving it is hesitating and jerking.
It sounds like you have a bad MAF (Mass Airflow Sensor). This is in your air inlet tube, pull this out and check to see if there is any corrosion on it. If is one that has a coiled exposed wire, then ensure that the wire is not broke.
Posted on May 19, 2009
nathan
  • 634 Answers
SOURCE: Service engine light keeps coming on
need to scan for codes and find problem code some part stores do for free
Posted on Jul 06, 2009
Anonymous
  • 431 Answers
SOURCE: my ford focus zetec 1.8 keeps over revving when
Hi I an Vortash there are a few things that can cause this ... Air at the inlet manifold caused by a faulty gasket ?.... Air leak in the Brake servo causing loss of Inlet vacum ( this would be noticeable with the fact that brakes would be a little spongy but not always and sometimes the engine revs increase when you put the brakes on when staionary ) Faulty throttle cable ... faulty throttle sensor .. best way to find out is to have the car checked out on a Krypton tune machine ( or equvalent ) to determine the fault otherwise you could spend out on un nesscasary parts .. at least the machine would pinpoint it for you .. It is always adviseable if you do your own repairs to get hold of a Haynes manual for your vehicle it will tell you all the best ways of treating most of your cars problems cheaply and efficiently hope this helps Regards Vortash
Posted on Jul 13, 2009
Wiring my stanley 500 amp jump starter
Not sure what the question is. These units have a sealed gel cell battery that can be replaced (Have done that) and they do fail after several years. Is yours charged? https://www.stanleytools.com/products/automotive-tools/other-tools/power-station/500-instant-1000-peak-amp-jump-starter-with-compressor/j5c09 BE sure last connection when jumping is negative and body to body - away from battery
Feb 28, 2018 | Stanley Vehicle Parts & Accessories
My Stanley 500 1000 amp charger/compressor won't charge??
Depends how long the unit has been just 'sitting' without being used! My neighbour had a similar problem after leaving his for over a year unused. The battery that's in it simply died. In order to maintain these units in good working order they need to be used regularly - that is charged and discharged. The unit may need a new battery I'm afraid!
Jun 22, 2014 | STA-J5C09 500 Amp Jump Starter w/ 120V AC...
Stanley fatmax instructions
Leave it on the charges as much time you can. Even though the charger indicates that is charged after 1 - 2 hours allow it to be on it as much time as you can (even 2 days). This procedures maintains the battery to be used more times.
Nov 23, 2013 | Stanley Fat Max 10 Watt Lithium Ion LED...
Tool; light blinks 9 times battery is charged pronto m51 tool light blinks 9 times chair won't move
Please download this manual and go to page 26:
http://search.aol.com/aol/search?&s_qt=sb&q=pronto+m51+error+code&tb_oid=07-01-2013&s_it=amonetizetest1-ie&tb_mrud=07-01-2013&tb_uuid=20130107163427450
Jan 22, 2013 | Health & Beauty
How to load blades on stanley #10-788
This knife is ****. To load... you have to push the slide all the way forward. Make sure the switch is set to unlock. PINCH THE BLADE WITH YOUR FINGERS AND WIGGLE IT INTO PLACE. Then you have to use every ounce of thumb power to relock the switch.
Once you are done, the blade will still come out in 9.9 / 10 times you cut something.
Nov 08, 2010 | Stanley Utility Knife
Adress needed
United States
Canada
Stanley Tools
1000 Stanley Drive
Concord, NC 28027
Attn: Quality Assurance
Stanley Canada
1170 Invicta Drive
Oakville, Ontario L6H 6G1
Feb 23, 2009 | Farberware Stanley Power Return Tape...
Stanley tape measure clock set time
On the bottom of the stanley clock you will see a little area that you put a coin in and twist,it will pop open to the battery and setting knobs.
Nov 03, 2008 | Watches
Measuring Tools & Sensors Logo
Top Stanley Proto Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Stanley Proto Measuring Tool and Sensor Expert? Answer questions, earn points and help others
