Question about LG Audio Players & Recorders
How to adjust speaker tone on LG model # 55LB63
2 Suggested Answers
6ya staff
SOURCE:
deandrwp72
Dean Platt
  • 23 Answers
SOURCE: How do I remove store mode off my lg smart 55LB63 tv
Access the MENU features and select the OPTIONS menu. Scroll down to the INITIAL SETTING option. Select the SETTING MODE option and press ENTER. Step one should allow you to choose between IN STORE and HOME. Choose HOME, press ENTER,
Posted on Nov 09, 2014
Nov 09, 2014 | Televison & Video
I am getting no sound when making a call or answering a call and cannot put my phone on speaker phone either. My ring tones and alert tones work.
Make sure the incall volume is set to loud enough. You should be able to use the settings menu to adjust the in call volume. It may be under something like "Call settings"
Mar 13, 2011 | LG VOYAGER VX10000 Cellular Phone
Lg xenon, need help turning off keypad tones.
go to your current profile and to edit, there you can find the warning tones and keypad tones levels, you can adjust there, else go to tone settings..
Jun 09, 2010 | LG Xenon GR500 Cell Phone
How to adjust speaker volume on the fujitsu phone
go to settins and tone select a tone and it will show u a volume setting... :)
Mar 11, 2010 | Lands Phones
LG GC900 stuck on silent
Hi
Since you have done all the necessary checks and the phone still stays on silent, then the problem is from the speaker which is where ring tones come out from when you receive a call or text message
The solution is to have the speaker replaced because it is no longer working. A repairer can help you replace it if you cant do it yourself.
Cheers
Mar 11, 2010 | LG VX3100
How do I turn off the ringer volume??
I found this at hp website.
Adjust the volume
Your HP all-in-one provides three levels for adjusting the ring and speaker volume.
The ring volume is the volume of the phone rings. The speaker volume is the level of
everything else, such as the dial tones, fax tones, and button press beeps. The default
setting is Soft.
1 Press Setup.
2 Press 4, and then press 6.
This selects Basic Fax Setup and then selects Ring and Beep Volume.
3 Press to select one of the options: Soft, Loud, or Off.
Note If you select Off, you will not hear a dial tone, fax tones, or incoming ring
tones.
4 Press OK.
Feb 22, 2010 | HP OfficeJet 6210 All-In-One InkJet...
How do I use the remote to cont bass & treble for rxv-657 reeiver
No, Tone controls are on the front of the unit only. If your passing video thru the unit you can go into the setup menu from the harmony and adjust all the sound parameters that way "on screen" The only "EQ" capabilities are for the Center channel only. You can adjust "speaker size". "Large" setting will give you a little lower response. "Small" will crossover the speaker at "100hz" That's about as far as tone adjustment goes on this unit. Hope this helps
Jun 30, 2009 | Yamaha RX-V657 Receiver
The phone doesn't ring, there is no speaker phone, and no tones when you dial or text.
Try using the side keys to adjust the volume. It sounds like the phone is on silent. Go into the audio settings and play around the ring tone, text, dial tone sounds and settings until you feel that it is appropriate for you.
If the phone is still not responding with sounds or tones after you have set the audio settings, the phone might be defective and you may need to have the phone company look at it.
- Neal
Apr 27, 2009 | AT&T LG CU515 Cell Phone - Black
How do I use speaker phone on the LG KF310?
To turn speaker phone ON/OFF during a call, press and hold navigation "OK" button.
To set ring tone go to 9. Profiles > select > Personalize > Call Alert Type.
Apr 01, 2009 | LG KF310 Cellular Phone
LG Prada Loud Speaker & Exculating Ring Tone
press the lock key on the side during a call to activate the speaker phone option and then press the required touch button on the screen.
Piyush
Jun 10, 2008 | LG Prada KE850 Cellular Phone
32 people viewed this question
Top LG Audio Players & Recorders Experts
Marvin
Marvin
PNiss
patseamur
Level 1 Expert
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
