SOURCE: power seat issue
Get out your voltmeter, unplug the connection to the seat's motor, underneath the seat, and hit the switch. if youve got power going to the motor then youll need to replace the motor. If not, it's probably the switch. Also make sure the wires are not cut or damaged somewhere between the switch and the seat.
SOURCE: Driver's power seat will not move backward
check fuse.if fuse is good check for power at seat motor.if yes replace seat motor.if no check wires at switch.if wires is not loose or broken seat motor switch could be bad.
SOURCE: will not move
The transmission is shot. A common problem. Mine died after 3 years and 200 hours of use. Estimate to fix was almost $2000. I scapped it and bought a better mower. There was a rtransmission design defect in the RZT series.
SOURCE: My 07 street glide won't start.when i turn the key
Turn the handlebars to the left and lock them with the key. Once locked, unlock and try to restart, this resets the alarm on my 2008 FLHX.
SOURCE: power seat won't move backwards
I had the same problem some one on one of the web-sites solved his problem by banging on the track rail in the front while pushing the seat button back after a good few bangs it unjamed and works great now .I feel like I saved at least $1500 by dealer rates.
