SOURCE: how long will one pound propane tank last
The 16.4 oz propane bottle contains 1.02 pounds of propane.
1.02 lbs propane equals 16.320 oz
16.320 oz equals 22.032 BTU’s.
The RMC-8001SS has two settings, maximum and minimum
The Max setting is rated at 8,000 BTU hour.
22.032 divided by 8,000 equals 2.754 or 2-3/4 hours
The Min setting is rated at 4,500 BTU hour.
22.032 divided by 4,500 equals 4.896 or 4.8 hours
One 16.4 ounce bottle will burn 22.032 BTU’s @8,000 BTU’s per hour for a period of approximately 2-3/4 hours and @ 4,500 BTU’s per hour for a period of approximately 4.8 hours.
SOURCE: i have a small dyna glo that takes a propane
There may be dust building up in the ODS safety pilot assembly. The simplest way toresolve this is to flish the pilot with rust buster. Why rustbuster? It has a telescoping tube that makes it easy to direct the squirt into the pilot. Let it dry then retry. You will be amazed.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: My Mr Heater Buddy heater 4000 to 9000 btu unit
it could be down to the draw off the tank pipe too small or reg is not for a 20lb tank , going to lock out check reg pressure should say on the side , or take hoes and reg off tank , put it back on and turn gas on slowly see if this helps
SOURCE: i have a mr heater
Frankly, it would be easier and less expensive to purchase a new one. Once water gets into one of these, they're pretty well shot and unsafe to operate.
