I have the motor for your 1584. Please call toll free 877-565-4861or send an email to [email protected] with your contact info please
SOURCE: Electrolux Z8240 model vacuum cleaner
Inside ,the dust collection container, there at the far end is a white cone shape (another filter). I think you may find this covered in lint etc and if you reach in with your hand you can just pull the stuff off. Happened to me around the two month mark and I THINK, so far, so good. My machine is now not switching off and flashing lights at me and the suction is back to fabulous. Found this information on another obsure website. You would think electrolux would mention it in their "Troubleshooting Guide" GOOD LUCK
SOURCE: Eureka canister vacuum cleaner Model 6865
The 6865 has a high rpm AMTEK Lamb motor, Brushes will seldom solve the problem at this stage.
Once the sparking and burning starts the conectiion between the brush and commutator is arcing and burning. If the sparks are blue, save your time.
A good service tech will run in brushes with a seating stone and a low voltage setup to allow new brushes to seat, but this is generally best accomplished on heavy duty , lower rpm motors.
IF YOUR ARMATURE IS SCRATCHY LOOKING OR WORN LIKE AN APPLE CORE,OR THE SEGMENTS ARE NOT PARALLEL IN THE SPACING YOU WILL NEED A NEW MOTOR.
SOURCE: I have a 15 yr old electrolux genesis upright
Fip it upside down and hit the roller with a malett
http://evacuumstore.com/c-99-electrolux-belts.aspx?manufacturerfilterid=0
SOURCE: Electrolux powernozzle not working
mine was the power head neck itself the handle got twisted to far and broke the wire a new neck cost 37 bucks online and i installed it myself wires get attached color to color and screw the head back together. it worked just like new!
