SOURCE: mower doesn't seem to be
is this a cmm1200 24v mower. if i am right then the charger should be replace.
SOURCE: batteries aren't charging up. Chair want go.(Golden Compass)
That`s most likely your problem. When left uncharged for that long of a period,the batteries will discharge below 12 voltDC. The charger only recognizes 12 volts and up. So the charger can`t bring your batteries back up over 12 volts. You will need to get them on a slow charger,like a car charger or have them replaced. If you know someone or have a voltmeter,set it on DC and check each battery. If it is below 12 VDC,they need to be put on a slow charger or replaced.
SOURCE: YardWorks 19'' 24V mower not charging
JIM I HAVE SEEN THIS ISSURE MORE THAN A HANDFULL OF TIMES, THE MAIN PROBLEM IS A LOOSE WIRE TO THE MOTOR HEAD, POP OFF THE COVER AND INSPECT. IF THAT DOES THE TRICK THEN GREAT!!! IF NOT THEN U HAVE INTERNAL MOTOR ISSUES THAT WILL BE COST PROHIBITIVE TO REPAIR.
SOURCE: My Duralast Gold Jump Starter does not take a
There is a battery inside which may need to be replaced. To check, run the compressor (it runs off
the battery) - if the compressor dies quickly, then the battery has failed to charge and would
need to be replaced. You may want to check your Warranty Management software (or
shoebox) to see if your Starter/Air Compressor is still under warranty - if so, replace it.
Duralast products are carried exclusively by AutoZone, Inc.
The Duralast web site: www.duralastparts.com is useless - it only shows automotive parts,
and I cannot find the product at www.autozone.com, so it seems that AutoZone fails to support this
product with replacement batteries or other replacement parts (or even an online Users manual).
SOURCE: Though my Worx WG781 cordless
Could be.Those batteries leak charge even when not in use.I would let it go for 24-48 hours just to be sure.Unless the batteries or charger becomes very hot.
