SOURCE: Ge side by side - high low humming noise from freezer section
I have a hotpoint HSS25GFPJWW fridg. The coil that opens the flapper door for the ice was bad so i replaced it . Now when i push the leaver in to get ice the fridge shut's down like ther is a large power drain. This was doing this before i replaced the coil but the flapper door was not opening then now it opens. It evens shut's the compressor off.
SOURCE: GE side by side refrigerater is not cooling on one side.
sounds like ayou could be having a problem with the defrost system pull the back cover off and you will see a metal bracket about half way up the coils and one at the bottom some models just have the one at the bottom these are defrost heaters check and see if one is burned out if so defroset replace heater and you will be ok if heaters are good check at the top of the coils there is a small round thing cliped onto one of the coil lines with 2 wires coming out of it this is a defrost bimetal or defrost thermostat now for this check the bimetal has to be cold and you need an ohm meter it is a simple test when cold it should read close which with and anolog meter will peg the neddle a digital will read 0.0 -0.2 this means this part is good if the needle does not move or you get no reading it is bad replace it now if the heaters and bimetal are good there is and evaporator thermister also located on the evapoator it is a small white look like a small bulett it could be sending the wrong information to the mother board this part is about 10.00 and the mother board on theif you still have a problem im afraid to say you mother board is bad replace it and you should be good to go with out all the snow it runs about 150 - 200 dollars depending on who you get it from.
SOURCE: /gss22wgpjbb Ge side by side fridge Keeps freezing
automatic defrost its not coming on check the heather or hi limit
SOURCE: The frdge side stopped cooling. the freezer side is fine - help!
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck & thanks for using fixya! Mike p.s. please don't forget to rate this free solution.
SOURCE: Fridge and Freezer Not getting Cold
Your defrost system is at fault.
With this brand it is most likely the defrost thermostat and defrost heater located behind the back freezer panel.
Remove the shelves and bin,then remove the freezer panel. Defrost the ice manually.
Replace the thermostat and heater assembly.
Testimonial: "Excellent Diagnosis. Lower Defrost Heater Failed."
Thanks for contacting Fixya.com
If you have a fridge with a working light, but no cold air, the first thing you should do is check the temperature setting to make sure it is set properly. Next, you will need to clean the refrigerator part known as the condenser coils. These are located on the back of the fridge, and these coils are a refrigerator part that gets very dirty. Cleaning them can restore lost efficiency, but you will need to disconnect the fridge first before cleaning this set of refrigerator parts. You should also insure that there is a three-inch dead space between the refrigerator and the walls near the unit.
Thank You
