Exercise & Fitness Logo
C
Chuck ealey Posted on Oct 19, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Fitbit sleep report has stop reporting. How do I get it working again?
Joseph Massimino
Level 2:
Habit-Forming:
New Friend:
  • Expert 67 Answers
  • Posted on Oct 23, 2019
Joseph Massimino
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
67
Questions
0
Helped
22920
Points
166
The battery might have gone bad, or it is defective. Call Fitbit and see if they will repair or replace it. They don't just stop working for no reason, as I said, the battery might be dead and need changing or charging, or it needs to be repaired or replaced by Fitbit. Call them if you are no sure.
5 Related Answers
Soulvisitor
Soulvisitor
  • 1113 Answers
  • Posted on Nov 14, 2007
SOURCE: fax transmission reports
From mfc mode 1,7,1 (xmit report)or from fax 7,1 is right but then you need to arrow across from off to on or on+image to enable report printing not just on error, then set
Anonymous
  • 215 Answers
  • Posted on Mar 30, 2009
SOURCE: UNABLE TO REMOVE SLEEP MODE
you can't take it off of sleep mode. the only thing you can do is set it to go into sleep mode anywhere between 0 to 99 minutes. you do that by pressing "menu, 1, and 8." there, you can input how long you want sleep mode. no way of completely disabling. i'm thinking that somehow, it must have gotten set to 0 minutes.
hth,
razors
Anonymous
  • Posted on Apr 06, 2009
SOURCE: Repeated Fax TX report printing
Solution #3 solved it for me. The report kept printing over and over, so I used the menus (roughly) mentioned in Soluton #3 by guest.
My problem was the printer was trying to print the TX Error Report with the image attached. That made the report too big for standard sized paper, so the machine kept telling me to check the paper size, and I'd hit 'OK', and that made the machine try to print the report again, for it continued to think it had not printed a complete report.
Here's what I did...
Go to: Fax Menu
Arrow right ( >) to Maintenance/Settings, hit, 'OK'
Arrow right to (>) to Device Settings, hit 'OK',
Fax Settings, hit 'OK',
Arrow down ( v ) to TX Settings, hit 'OK',
Arrow down ( v ) to TX Report, OK
Select 'Print error only', hit 'OK',
Attach TX image, Select 'NO', hit 'OK"
With the instruction to not attach the TX image, it will print out the error report without the TX image, the report will fit on the paper, and it will clear this problem.
Anonymous
  • Posted on Feb 15, 2010
SOURCE: How do i stop my Brother 2920 fax machine from
how do i use my lexmark 6500 fax machine with majic jack?
Anonymous
  • Posted on Oct 14, 2010
SOURCE: In Win Vista my new Canon mf4370dn is being reported as offline.
Go to this canon site and install the firmware update. This was happening to me all the time until I installed this firmware update and now I can print to it all the time. I used to have to turn the printer off and back on just to get the printer to wake up.
http://canoncanada.custhelp.com/app/answers/detail/a_id/20228/~/imageclass-mf4370dn-firmware-update
2answers
Fax transmission reports
What you are explaining should work. If you need prior activity reports from previous faxes, you can press Function then 2 (Act. Report)
I think you might need to press Function, then 7 then 1
From the manual:
Transmission Verification (Xmit) Report You can use the Xmit Report as proof that you sent a fax. This report lists
the time and date of transmission, and whether the transmission was successful.
When the feature is OFF, the report is printed automatically only if an error occurred during transmission. If the report indicates NG, send the document again. If the report indicates you should check the readability of certain pages, resend those pages.
If you typically send multiple faxes to the same destinations, you may need a reminder to identify each fax transmission. You can select OFF+IMAGE or ON+IMAGE to print a portion of the first page of the fax message on the report.
1 For the FAX, press Function , 7 , 1 .
For the MFC, press Function , 1 , 7 , 1 .
2 Press or to select OFF, OFF+IMAGE, ON or ON+IMAGE and press Set .
3 Press Stop to exit.
Hope this helps you.
Mike
Why is my Fitbit altra showing my sleep patterns not my sleep stages?
Do you wear your Fitbit tight enough for it to record (3 continuous hours min.) your heart rate? it's happened to me when my Fitbit became loose during the night and the system couldn't collect enough data to analyse and display the sleep stages, that was even pointed out in the morning by Fitbit in the sleep analytics section in the app.
2answers
Fitbit versa not tracking sleep
Happens to me too. Not sure if it is warranty issue.
My fitbit is not syncing
My Fitbit suddenly stopped synching with my iPad and iPhone. It is fully charged and the lights show on my unit.
Who do I contact in regards to my fitbit? I have had 2 since august and the bracelet has broke again.
Contact.fitbit.com You will also find thos info in the warranty, this can be found at the bottom of any page on fitbit
My fitbit flex died - cannot wake it up; also it's tied to my cell phone and that doesn't respond - totally blank!
How to fix broken Fitbit - sync Fitbit with phone app - PC ...
www.pcadvisor.co.uk/how.../how-fix-broken-fitbit-sync-image-3499292...
May 15, 2015 - Fitbit Flex, Fitbit One, Fitbit Zip, Fitbit Force or Ultra not syncing with the Fitbit app ... To get the Fitbit app sync working again restart the Fitbit tracker. ... charger, has a battery charge but is not lighting up, or isn't tracking your steps. .... I've already done all the obvious stuff: turning off my phone, turning off and ...
Fitbit Flex review - The disappointment we've all been ...
blog.hyperexpert.com/fitbit-flex-review-the-disappointment-weve-all-be...
May 5, 2013 - My wife and I are both in good shape, we both wanted the Flex just to ... app, wait for the device to finish connecting and syncing to your phone, ... to sleep mode, I have to do all of this? and then again to wake it up? .... Also, doesn't the manual say "not" to wear it in the shower? ..... I appreciate any response.
1helpful
2answers
How to change fitbit flex device sleep settings to sensitive?
Great question!! Any luck going into settings on your computer to see if there is an option for that?
Top Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
