SOURCE: Power button Flashes
Bad Convergence circuit , replace 2 STK392-110 & fuse will take care the problem
SOURCE: Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
SOURCE: My intercom button flashed red to green.
Each telephone must be connected to line 1 and line 2 for
proper operation. The remaining lines 3 and 4 may — or may not —
be
connected to each station as you desire. First plug in the battery,
then the phone lines (1 & 2 are mandatory), and third the power
cord. If your intercome LED is blinking red and green, then press:
STORE IN, followed by "INTERCOM" followed by a free intercom# (i.e.,
any of the memory buttons 1 through 16 not already assigned to another
telephone set). Then wait for the phone to go through its initiation
sequence during which it searches each of the four possible lines.
After that concludes, you should get dial tone on your active lines.
:-) Marco
SOURCE: Maytag Jetclean Dishwasher EQ Plus - Lights flashing
either the control board or the control panel needs replacement. Most likely the latter. There is a possibility that both parts failed also. Usually water gets inside the touchpad, corroding and shorting the touchpad. Good luck
