It just stopped working one day. E appeared when I pushed on. No other information will display. I figured the batteries were dead. So I had new ones (tested-the batteries are good) put in and it STILL reads E.
How can I fix this? I have a glass top Salter scale. I think it goes up to 11 lbs.
Hallo I have problem witch kitchen scale Salter.E appear when I pushed on and it takes 3 sec
How can I fix this problem
Than You
I have a older Salter 6300 Kitchen scale and I accidentally dropped a full unopened soda can and it landed right on my scale. It was then reading "err" whenever I tried to weigh anything. I fixed it by recalibrating it. You hold down Off and On simultaneously and this will bring up "Cal" and then a 4 digit number will show up 3 thousand something. You then put 15 quarters for 85g or 20 nickels 100g. That 3000 number will move up in grams by what you add. Next hit OFF once and enter the weight in grams you added. For me it was 85g so I put 0085. Hit off again and you'll come to another 4 digit number. I figured this number is for the format or max weight allowed after toying with it by entering all kind of numbers. I found entering 9333 works best. Hit OFF once more and another 4 digit number shows. Here I found 0001 to work. Hit OFF one last time and you should see CAL F meaning calibration is finished. My scale is now working fine again.
I forgot to add that you use buttons on lift "zero" and"g/oz" to cycle through and change numbers.
Hi Jason! I made it to the 9333 part and after I hit "off" I get "Err" again. Can you explain a little more how you came up with 9333? Thanks!
Thanks. Worked first try. Still having some difficulty in getting the on button to work reliably though.
jason, this is pure genius, even after calling salter and them telling me scale is broke, send it back~you have come up with solution! thx
