Apple iPod nano Logo
Posted on Sep 18, 2009
Ok I plug into radio and turn on shuffle but still nothing coming on the radio, we are getting music still from the radio stations, its the green little apple shuffle
Anonymous
Level 1:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Sep 18, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
14
Questions
0
Helped
6324
Points
41
If you are plugging this into the radio with a regular audio cable, (headphone jack out of iPod, to AUX jack on car radio) the car radio needs to be on auxillary. Depending on your car, you can change the mode from CD, to Radio, to Tape, and to Auxillary. If you have it on auxillary and it's still not working, you may try a different cable. Hope this helps!
1helpful
2answers
What staion do i put my car radio on
You need to manually tune your radio on FM to whatever frequency you have chosen on the tune cast.
1helpful
It wont charge it blinks three times then stops
Hi,Okay, well, I don't want to be a shill for Apple (I mean, heck, I had to buy my Shuffle, so it's not like they're sponsoring this in any way! :-) so let's talk about the color sequences and what they mean.
First off, there are a number of different functions that are denoted by different color sequences, so flashing green might mean one thing when you're listening to music, and something else entirely when it's plugged in and charging or syncing with your PC.
The primary functions are powering on, charging, syncing, and general feedback. Let's look at each.
When you turn on your ipod shuffle, the light will indicate your current charge level:
green = 30-100% charge, you're good to cruise
orange = 10-30% charge, low, but still good for a short workout
red = less than 10% charge, time to plug it in
no light = too late, you've run out of juice
If you see an alternating pattern of green-orange-orange then your Shuffle's crashed or otherwise needs to be restored. Needless to say, that's not a good thing, but probably easy to fix when you hook it up to your PC or Mac.
When you're charging up your shuffle, there are three possible light states:
orange = charging
green = fully charged, unplug whenever you're ready to go
flashing orange = busy, either syncing or in use as a remote disk
When you're playing some music, you can see visual feedback on what's happening and what state you're in:
Press play and
solid green = you're playing music
flashing green = you're in pause mode
Press and hold play and
green-orange-orange-orange = you've disabled your buttons
orange-green-green-green = you've reenabled your buttons
That's bound to be one where people panic and fear that they've broken their shuffles, I bet. If your buttons aren't working at all on your Apple iPod Shuffle 2nd Gen, then press and hold your Play button to see what light sequence you're given. This is also shown by the Shuffle flashing orange when you push a button too.
If your player flashes alternating green and orange, you have no music in the shuffle. This can be because it's fresh out of the box, or because, well, something's happened and the music has vanished. Either way, time to sync with your iTunes library.
If you're seeing a flashing red sequence, you're just about out of battery and just need to plug it in so it can charge up.
Finally, Apple has some good tech notes on the new Shuffle too that you might want to check out if you're still a bit baffled by this tiny engineering wonder: Understanding status light behavior, Shuffle Second Gen, Frequently Asked Questions and iPod Shuffle Support Overview.
2answers
Music from phones, how to change the music?
A Panasonic phone plugs into a Panasonic KSU (key service unit) and the cabinet has a MOH jack on the side. That is fed by a music source which is probably a radio, in your case. There are several MOH players that are better and not subject to the penalties we have in the U.S. with music licensing agencies, but that's another thread.
Find the cabinet and you can probably find the music source that's plugged into it. Then you can change the music.
Carl
Ipod won't work!!
I have solved it the problem is i downloaded music just into the my music libarary and not actually on to my ipod so it ment that there was no music on the unit lol!
Red light isn't indicating it detects source
I have the same model as you.
Plug in the transmitting unit into a good working power outlet. Make sure you have the audio connected to a loud source. Turn on the source device producing the loud audio to be transmitted to your headphones. (This being your IPod - Turn it full blast). Now see if the transmitting unit's LED light is on. Check headphones for audio. (May have to tune in the headphones till green and adjust its volume as well).
Note: Some radio stations bleed over into the headphones and you may have gotten the "Beautiful Music" from this radio station frequency harmonic anomaly. Keep tuning your headphones till you hear your music or audio source.
I recommend that the source of your audio have its built-in speakers off, while still providing audio out to your transmitting unit, via an external audio output. Check your source manual or look for audio jacks on the front or back. There may be a setting to turn this on and for the main built-in speakers to be turned off as well.
If this does not work, unplug the transmitting unit, and then plug it back in again, after waiting for about 10 seconds - all while audio is being provided to the unit. It should come on.
2answers
7helpful
My ipod shuffle won't charge
ok try this and see what happens. plug in the charger and let it charge for a while.
unplug it and find the switch on the top of the ipod which you will turn off. No Green will be showing.
wait 5 minutes and whic it to shuffle or play and you should have just reset you shuffle.
Good Luck
2helpful
Apple iPod Shuffle 2nd Generation Not working
I plug it in to my computer, and I-Tunes does't finds it, I was unable to load music
on it and I get the green light saying it is charged. But when I take
it off the computer, I get lights for two second and it will not turn on or play
music at all. Any suggestions?
Itunes and ipod are not cooperating with me.
I bought an Ipod shuffle 2nd generation yesterday, it charged all night and orange light was still blinking. Tried listening to songs and sometimes it would play but most times wouldn't. Took it back for exchange and same problem. Then I realized the problem is not with the USB plug or computer reoconizing ipod but in the docking itself. I applied pressure on the top side of docked Ipod and bottom of docking station and the computer recognized the Ipod. Release pressure and lose connection. The problem is that the docking station and earbuds do not connect with ipod and the fixes provided by apple doesn't address or fix this problem.
2helpful
4answers
Green/orange flahing light on IPod and no music.
From Apple.com Support Website. If the front status light on your iPod shuffle blinks orange and green when you press any button, then your iPod shuffle is experiencing some type of error. Try these troubleshooting steps to resolve the problem. To troubleshoot the iPod shuffle error light: 1. Turn off your iPod shuffle 2. Wait a few seconds 3. Turn your iPod shuffle back on again If this does not resolve the problem: 1. Check to make sure there are songs on your iPod shuffle 2. Use iTunes to add songs to iPod shuffle and try again If your iPod shuffle continues to display a blinking orange and green light, use iPod Updater 2005-02-11 or later to restore iPod shuffle, and then add songs with iTunes. If your iPod shuffle still shows a blinking orange and green light after trying all of the above steps, your iPod shuffle may need service. Best of Luck.
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
