GE Profile Performance is not draining all the way. There is an inch of water after every cycle.
This is usually caused by clogged drain it is the hose that leads to the water pump suction located in between the inner and the outer tub. you can usually feel around the hose by squeezing it if you feel a lump within the hose then all you have to do it remove the foreign material. you can do this by removing the top cover and reach over the bottom to try to remove it or by seperating the hose from underneath to clear the clogg.
Here
is a tip that I wrote that will help you with your dishwasher not
draining problem...
Dishwasher Problems - Water
will not drain
out
heatman101
Hi, 1
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
