M
MD ABDUS SATTAR Posted on Oct 18, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
KONICA MINALTA BZU 164 MAINTENANCE CALL M2 CALL SERVICE ?
Norman Weimar
Level 3:
  • Konica Master 7,035 Answers
  • Posted on Oct 27, 2019
Norman Weimar
Konica Master
Level 3:
Answers
7035
Questions
Helped
1913207
Points
11959
Mam/Sir
Replace the drum and the developer and preform TCR adjustment
5 Related Answers
Anonymous
  • Posted on Jan 01, 2009
SOURCE: NEED A MANUAL FOR Konica Minalta Dimage Z1
Found on the internet under the heading Free download for rhe Konica Minolta model Z1 sent via PDF.
Many thanks for your efforts on my behalf as I could not find it at the time of my request.
Ahappy new year to one and all.
Ronnie
kraggarwal_k
KR Aggarwal
  • 6 Answers
  • Posted on Nov 20, 2014
SOURCE: What is m2 code how cani reset in Konica Minolta
This is to display the count of the supplies life counter.
When the counter is reached to 0 life 1 will be detected and maintenance call M2 will be appeared.
The initial value is 40,000, and the countdown system is used.
Use Setting/Procedure
- To clear the count, use [CLEAR DATA] of the Service Mode.
joseph_pr655
Jojo
  • 478 Answers
  • Posted on Dec 22, 2014
SOURCE: konica minolta bizhub 164 showing M2 maintanaince call
You need to replace 1st the consumables before simulation/reset to prevent further damage to Bizhub 164.
  • 102366 Answers
  • Posted on Nov 16, 2016
SOURCE: Konica minolta bizhub 164 m2 reset
Do what it says and call service.
rajibdip6
Rajib Barman Varma
  • 23 Answers
  • Posted on Dec 15, 2016
SOURCE: proceed to continue using the machine konica minolta bizhub 165 when I get the message error M2
THEN CHANGE THE DRUM UNIT OR DEVELOPER
KONICA MINALTA BIZU164 MAINTENANCE M2 CALL SERVICE?
Any solution when Konica bizhub 164 machine display maintenance (M2) call service?
https://youtu.be/N4KwPUPuF7Q
press
menu
quick setting
left
left
quick setting
left
right
enter service mode
use up and down arrow keys
press data clear and off on
How to solve Konica minalto bizhub 164 maintenance call M2 call service
Replace the drum and developer unit and ensure that the counter for drum and developer is reset and that the F8 is run in service mode.
How clear Maintenance m2 call service this konica 164
Clear the counters first then Replace the drum and developer run the required function codes should be good to go
4helpful
What is solution for konicaminolta 164 maitanance call m2
M2 Call service.Maintenance M2, M1 Call service errors.To remove this error do the following steps.
1-Press utility button on panel.
2-Now press these buttons one by one, Press Stop, then zero, again zero, then stop,then press zero.
3-its the code to get into service mode.
4-After pressing above mentioned buttons you will enter into service mode.
5-Now select service choice option.select it by pressing OK button.
6-In service choice option you will see Maintenance count option.
7-Select it by pressing Yes or OK button.
8-There will be three options 0,1,2.
9-Select 1, it will show a new menu, with numbers, now press C button to clear the counter.After the counter is cleared.Select 0 and press Reset button.
3helpful
Konica bizhub 164 M2
1-Press "Menu
2-press Quick settings,
3-then press right arrow key 2 times
4-press Quick settings
5-then press left arrow then right arrow key.
17helpful
2answers
Desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
Top Konica Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
NOEL
NOEL
Are you a Konica Office Equipment and Supply Expert? Answer questions, earn points and help others
