A big capacitor in parallel with inverter
https://passive-components.eu/selecting-film-or-electrolytic-capacitors-for-power-conversion-circuits/
SOURCE: EMACHINE T6542
I don't see how removing the battery would help but tried for the same problem and it did in fact do nothing.
The fan races but the system never makes it to the Bios and never displays anything on the monitor. I suspect a chip is fried on the MoBo.
Maxum52, please post the solution if you found one.
SOURCE: Compaq Presario V3500. Power up - 4 beeps and flash power light.
Try to ask the company what is happening
SOURCE: split ac runs for 2 hrs and MCB TRIPS
Hi and welcome to FixYa. I am Kelly
This is a sign of a compressor that has an armature dragging internally or the winding has a short to the chassis inside the compressor. Placing your hand on one with an internal short to the case will definately get your attention. USE a meter! (lesson learned the hard way too many times)
It really is not wise to keep trying to use the unit in this condition.
1. Higher electric bill
2. When compressor finally burns up and contaminates coolant system.... purging and cleaning the coolant system can be as costly as the compressor replacement.
3. There is a remote chance there is a chaffing wire from the outside unit to the inside unit. (Very remote)
A Service Tech will do a running check where he verifies the running amperage of the unit. High amperage = a bad / dragging compressor.
Kelly
SOURCE: Microtek Inverter not fully charging the batteries
xenion pure shinewave inverter not charging fully
