Question about Garden
How to set the tine on and off camera systems ?
How do I change the tines
You have not shared which model and make of tiller you have, but many of them have a set screw or two holding each tine on.
You would need to loosen the screws, and maybe polish the shaft with sandpaper and oil it to get each tine off in order.
Some tillers use a different method of tine installation, since this can be patented or trademarked.
For example, some have the tines permanently attached to the shaft, so the whole shaft must be replaced as a unit.
God bless your efforts.
May 12, 2016 | Garden
Brand new tiller tines will not turn scv43
look to see if the drive belt fell out of place during shipping
Jun 06, 2012 | southland Garden Cultivator Tiller S-cv-43...
Just bought an older Mantis 2 cycle tiller. The tines engage when the tiller is started. Of course that makes it hard to start with the tines on the ground! I don't believe it was doing this when I...
if the idle is too high the tines wont stop due to the tiller tines are run by a "centrifuigual clutch" which means when you increase the throttle speed the tines will start to turn : there are 2 adjustments you can try,1) adjust the idle screw under the carburetor where the throttle adjustment and a triangle piece of metal touch(your throttle cable wire will be attached to this triangle) ,if the triangle and idle adjustment don't touch and there's a gap between these 2 pieces close the gap by adjusting the 10mm adjusting nut,this will correctly set the idle #2) adjust the idle adjustment screw talked about above till the tines dont turn with throttle set at idle or lowest speed setting
Mar 26, 2011 | Mantis 2-Cycle Tiller
Troy bult junior has new tines , runs to fast...
MAKE TWO PASSES SET THE DEPTH GUIDE SO IT JUST BREAKS THE GROUND, DON'T TRY TO DO IT ALL AT ONCE. SOON AS THE GROUND IS LOOSE IT WILL DIG MUCH BETTER.. IT SHOULD HAVE A FORWARD AND REVERSE FOR THE TINES, GEARS FOR FORWARD REVERSE DRIVE
May 19, 2010 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Acer Aspire netbook integrated cam. Message from Skype.. not installed Nothing in Control Panel Scanners and Cameras but is listed in Add/Remove software Was working 2 weeks ago
Try restoring your system to tine when it was working fine. Go to Start---->All Programs-----> Accessories----->System Tolls-----> System Restore This should guide you through the process of returning to previous state. Good Luck
Apr 26, 2010 | Acer Aspire 3610 Notebook
My tiller does not seem to be cutting deep enough
Hi there kimberly,
Here's what you need to do.
  • Make sure the depth stake (behind the tines) is up as high as it will go. This will allow the tines to go deeper.
  • Fire it up. Set the tine rotation to reverse (more mixing and twisting.
  • Make sure the tines are actually turning, Each side is held in place with a shear pin. In case something binds the blades, this pin breaking will save the drive train
  • Note how the tiller is balanced. Wheels in the middle. You can tilt it forwards or backwards.
  • Tilting forward allows the wheels to gain traction and move the unit forward
  • Tilting Backwards allows the tines to dig in. If the surface is too hard, Press down with your body weight. It will dig through.
I hope this work out for ya
Best regards
Mike
Apr 25, 2010 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
I have a Troy-Bilt PTO Horse (Horse III) 8HP TINES
The tines are very close to the housing and sometimes you do get rocks hitting,as for the dirt it should have side panels to keep the dirt in place.
May 07, 2009 | Garden
Garden Logo
Top Garden Experts
roeb
john h
Marvin
Marvin
