The reason why you cannot install Windows on your hard drive is this model Sony has a SATA disk controller. The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
you might be able to configure your set up using "Fdisk" a utility that erases and partitionjs your hard drive.Do a search and get to know its workings. Good Luck
You cannot downgrade Windows 7 from Windows XP by not reformatting the hard drive. You need to Remove Windows 7 first, before installing Windows XP Operating System. In order to use the Windows XP CD to fully reformat the Hard drive, follow the steps on the link below.
1 put widows XP CD in to your CD drive
2 restart your PC
3 it will boot your CD just put Enter
4 if not then selact boot option by presing F12 0r F2
5 it will start reding your CD
You can try also to do reformat your hard drive as fresh unallocated one before doing formatting again to install windows. And check your installation disk for scratches.
hi! there,set up exe. that was when your setting up win 98 you have to install that came from floppy disk before you can install win 98.there is an os win 98 in your system you have to delete that previous os before installing another win xp.restart ur computer. press F2 to open your bios set-up . then select bios set-up priority your cd-room drive second,your hard drive. last, quit and save set-up. and then your computer will restart. insert your cd windows xp then reinstall your window xp. delete the previous os then follow the set up on your window xp until you install your new window xp.
When you attempted to reinstall Xp did you answer to install on a new particion or fix and repair existing? Reparticion hard drive or you can download a program ferom one of the hard disk makers such asWestern digital , reformatt the whole drive with that then reinstall windows.
Umm...is your laptop crashed??? Usually ntlldr issues ****. try to delete the former installation so a new ntldr file can be installed so as to not conflict with the damaged ntldr file that is on the pc blocking the install. It sounds like your setup is ok...at the very least get another xp cd to make sure the disk is not damaged that you are loading windows from.
