SOURCE: Cub Cadet PTO will not engage
Do you have a volt meter or a 12 volt test light?..if you do you can see where you are losing your voltage at..but i would suspect the PTO switch is bad..i hope this has helped.....Keith
SOURCE: engine cutting off after engaging the pto (mower deck) JD 317
its likely to be a switch playing you up try hard wireing the switch to see if it stops this cutting out first, do one switch at a time till you fine the one playing up
SOURCE: My craftsman 944.609961 16HP lawn mower won't
my tractor cuts out and i have to jump it to start . i have replaced the battery and selenoid. help?
SOURCE: safety switch testing on S92 riding mower
it should be under the seat . u can try to test in by just getting up and down of mower while at a stand still and blades are running. when u get up blades should stop .
