How to set zone on silicon projection atomic clock?
How to change time zone on silicon projection clock?
3 Suggested Answers
6ya staff
SOURCE:
Chris Hauck
SOURCE: silicon scientific atomic projection clock did no ...
I have one of these, and look for the manual on the 'Net every time DST changes, and eventually figure it out. Here's how: (1) Hold down the ALM/SET button until you get past the alarm setting and you see 24H or 12H. (2) Step through the settings by pushing the ALM/SET button, changing each as desired by pressing the +/CYCLE button. Eventually you'll wind up with the time zone indication flashing (it's really tiny, and appears just below the time indication). Press the +/CYCLE until you get to the desired time zone. (3) After the screen quits flashing, press the -/DST button to get the desired setting. I hope this helps, and that I can find this post again next time change!
Posted on Nov 09, 2011
emissionwiz
Marvin
  • 85206 Answers
SOURCE: How can I set the time zone on a Silicon Scientific atomic projection clock.
Try this Press the bottom left button thru the alarm sets, till you get to a -5 (ET) / -6 (CT) / -7 (MT) / -8 (PT). Then, press the upper left MODE button once. Now the -5 will flash, allowing a change. If you just went EAST you need to press the bottom right button once [ex: MT to CT - go from -7 to -6] If you went WEST, press the top right button once [ex: ETt0CT-gofrom-5to-6]
Posted on Nov 20, 2016
Nov 20, 2016 | Home
How do you set the time zone on a silicon scientific atomic projection clock?
Look for a time zone selection switch on the rear.
Nov 14, 2016 | Home
Silicon scientific atomic projection clock did no reset for daylight saving. Help
May 19, 2010 | Watches
Can't figure out how to set the time zone
I just pressed and held for about 3 to 5 seconds the button with the +/- on the bottom of the clock and until it showed the part of the US that I was in.
May 18, 2009 | Honeywell RC182WR Atomic Alarm Clock - Red
I need to change time zone on atomic clock to EST
I need help setting the time zone on the sharp atomic clock model #spc364.
Apr 18, 2009 | Bose Wave Radio
Changing the time
you can go to http://www2.oregonscientific.com/assets/manuals2/bar338pa.pdf to see or print the user's manual.
If you don't want to get the manual, here's what you do to fix it. . . . .
*note: you need to do this anytime you change the batteries.
1) open the battery cover
2) on the left side you'll see 3 little buttons labeled a)zone, b)C/F c)reset
3) push the reset
4)push the zone button until your time zone is highlighted on the front display
5) look at the front display & if you see a blinking "radio signal" icon at upper left of time numerals
don't do anything else. The time, date, etc. will automatically synchronize your clock with the US Atomic Clock. This could take up to 10 minutes. As long as the "radio signal" icon is blinking, it's working on it. When the icon doesnt' blink, it's set. Cool, huh?
6) if the area you live in can't receive the signal from the Atomic Clock, instead of a blinking "radio signal", you'll see just a bare antennae. Since you probably set your clock manually, that's what it shows now before you do anything.
7) after you push reset & set the time zone do NOT touch any other buttons to set anything!!! (I know it's difficult to leave things alone, but just sit on your hands). Pushing the "clock" button or the up & down arrows will stop the radio signal & change to manual functions. Look at the signal icon mentioned in 5) and 6) above. If you only have the bare antennae icon. . . . . go ahead & set the time/date yourself. You have no signal.
Enjoy your clock!
debkresh
Jan 25, 2009 | Oregon Scientific FM Weather Projection...
Cannot properly reset skyscan atomic clock
press set button repeatedly -you get timezone mode and change your wished time zone and select your zone then press set button to normal mode and adjust the current time.
thanking you.
Nov 19, 2008 | SkyScan 86709 Atomic Wall Clock
Atomic clock sky scan model 87801
Press set button repeatedly -you get timezone mode and change your wished time zone and select your zone then press set button to normal mode and adjust the current time. kindly gave your rating after you read this.
Nov 07, 2008 | SkyScan 86709 Atomic Wall Clock
Sharp Atomic Clock spc 373 won't display correct time/zone
To change the time zone press the "time" button, on the front the space that shows the date will change to show the time zone. With the time zone showing press the "up" or "down" button to get to the correct time zone.
Sep 23, 2008 | Zapf Chou Chou 716212
 Grubhead
Grubhead
Marvin
Marvin
