Is this the kato voyager emergency radio? I'll assume it is. New or used? If new, return it. First, verify it works. Are you in an area where you can receive radio signals? Do this without any external add on antennas, just the original one. Go one? Now you can test the external antenna. I suspect your external antenna is shorted out. I see it more often than not. Redo any antenna connector you put on, be especially careful to keep ANY braid wires from the center. Even 1 will short it out. Test again. Works, you are done, Not? likely a bad radio or a bad antenna. Try another antenna if you tested the radio.
SOURCE: Phillips Magnavox TV-is this HD?
then you will need a converter box,there is no analog signal anymore,it was changed to digital,your tv is not hd if you dont even get one channel,you also need a hd antenna,
SOURCE: Where is the antenna wire or plug located from radio to external antenna?
Possible failed amplification unit (may be internal to the radio or may be external somewhere in the car, usually in the trunk or under the rear seats)
Testimonial: "What is in the trunk my antenna is on the passenger side front top portion of the fender, which to raise it I have to push the antenna button on the dash."
