SOURCE: conair scale ww36gd err reading
I have a WW36DG digital scale and most of the instructions are the same, so far as I can see. When you tap on the scale, 888.888 appears. It is just seting itself. If you step on the scale before it reads 00.0 it wil give you a Err signal. If you stepped on the scale after it read 00.0, and an Err signal appears, either your battery is very low or it is malfunctioning. it does have a 10 year warranty on it. For the person wanting to set the scale, here are the directions. Good luck.
Customizing Your
Weight Watchers® Body Fat Monitor
1. Tap center of scale platform with foot to activate digital display (display will
flash).
2. Wait for "0.0" to appear in display window.
3. You are now ready to input your personal data. Firmly press the SET button
located below the display.
Enter User Number
• P-01 will flash in display window
• Press UP or DOWN arrows to select your individual user
number (Ten user numbers available: P-01 through P-10)
• When selected user number appears in display, press SET
button to save user number
• The scale is now ready for you to enter your height
Set Height
• "Ht" (height) will flash in display window
• Press UP or DOWN arrows to scroll to your height measurement
• Press SET button to save height
• The scale is now ready for you to enter your age
Set Age
• "Age" will flash in display window
• Press UP or DOWN arrows to scroll to your age
• Press SET button to save age
• The scale is now ready for you to enter your gender
Set Gender
• The gender icons will flash in display window
• Press UP or DOWN arrows to select male or female icon
• Press SET button to save gender
• The scale is now ready for you to weigh yourself and to
determine percentage of body fat
SOURCE: Err 1 message on Taylor Lithium Elec Scale model 7346
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from
your scale. You may need to do this several times to completely reboot
the system. Please let us know if you have any questions or continue to
display the Error.
1. Remove the battery from the scale
2. Set the scale on the floor without the battery in place.
3. Stand on the scale for 10 seconds (still without the battery)
4. Carefully replace the battery without turning the scale on.
5. Using only one foot, tap the scale or apply just enough pressure to
turn on the display. (It should show dashes or zero's) IMMEDIATELY
REMOVE YOUR FOOT.
6. Let the scale turn off
7. Step on the scale for a weight reading
Regards,
Linda DLT
Consumer Relations
Taylor Precision Products
& Salter Housewares
2220 Entrada del Sol, Suite A
Las Cruces, NM 88001
Toll free - 800-289-0944
866-843-3905
Direct - 575-526-0944 ext 3172
SOURCE: Fluctuating weight on Digital Scale from one minute to the next..
i believe that, like most electronic scales, the first time you get on the scale you must step off to allow it to zero itself. Then step back on to get your correct weight.
SOURCE: Conair #WW78 scale doesn't reweigh
;i have a problem with the conair ww78. It does not reweigh. It shows the same weight each and every day. What is the problem and how can it be fixed?
SOURCE: I changed the battery on bathroom scale Salter 987
I had the same problem with my Salter 987 scale. Pull the battery out for about 10 seconds and put it back in. Then push the scale once so it turns on. After the blinking stops, push it once more. The scale will now zero itself. After the scale has zero'd itself it may turn off after a brief moment. It's now ready to use normally. If you're standing on the scale when it's trying to calibrate to zero, it will assume your weight is zero. Don't stand on the scale after replacing the battery untill you first complete the steps listed above.
