Refrigerators Logo
Posted on Sep 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Automotive r134a refrigerant in refrigerator compressor?
Can automotive r134a refrigerant be added to a R134a refrigerator compressor?
fmstark
Level 2:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 35 Answers
  • Posted on Sep 17, 2009
fmstark
Expert
Level 2:
Night Owl:
Answers
35
Questions
0
Helped
11628
Points
112
It is the same refrigerant however the car industry and the refrigeration industries purity standards ARE NOT the same!! as a rule refrigerant manufactured under the refer standard can be used for auto but not the reverse, you can use it but be forewarned chances are you will be replacing the compressor due to an electrical burn out
1 Related Answer
Gil Shultz
  • 3464 Answers
  • Posted on Dec 02, 2009
SOURCE: whats the working pressure of R134a in refrigerator
That question does not have a simple answer. The pressure is directly related to the temperature. You can go on line and get a table showing the pressure vs temperature. I would think 0 is a good starting point for the return temperature. High is also related to temperature. I would expect the high to be about 135 but that depend on ambient etc. You may have to have a licence to tap the refrigeration system and purchase gas depending on your locaton.
Good Luck,
Gilshultz
Replaced all A/C major components (compressor, filter-drier accumulator, and orifice tube) except condenser due to a seized compressor and failed clutch bearing. Flushed system and appeared to have no...
It sounds like you've done just about everything except to check if there is a bad or intermittent wire causing this or perhaps your low-pressure safety cutout switch is possible going bad causing the compressor to kick on and off?
The amount of freon i need to put in my 1991 toyota corolla ?
well in that year they used r12 refrigerant ! today they use r134a refrigerant they are not interchangable if you have already converted to r134a they you can call toyota and ask for specific amount although you really dont need to know all you need is a can of r134a with a gauge on it if it
75-80 degrees outside the pressure should be between 40-45 pounds if its 85-90 degrees between 45-50 pounds on the low side were you add it so basiclly keep adding till those pressures are reached
please do not add r134a if you have not had system converted over from r12
2helpful
Basic: How do I re-charge 1989 toyota corolla air conditioning system.freon re-charger ket how to install.
Hi!!
Unfortunately, the R-12 refrigerant that your compressor used was phased out on 1994. You will need to an Automotive A/C Shop to have the system evacuated, flushed, vacuumed, retrofitted and charged with R134a refrigerant. This job requires the use of specialized equipment and according to EPA regulations must be performed by a licensed HVAC Technician.
Once your system was retrofitted, if you ever need to re-charge refrigerant. All autoparts carry easy to use, instructions included, R134a refrigerant recharge kits.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Need to find were water filter is to change model R134a
R134a is the refrigerant that is pumped through the compressor. The water filter is for the water dispenser and the ice maker, it has absolutely nothing to do whatsoever with the refrigerant. If you have a water filter on your model, and its possible you dont, it will be located inside the fresh food section at the top.
1helpful
What is the refrigerant in my 1991 LS400 Lexus?
R12 is not sold no longer so look on the compressor for a tag of what freon to use. Conversions kits are sold for older cars to use R134a
1helpful
How do I remove the Ac oil in my 89 corvette when switching from freon to 134 . How much should be added and where?
I have upgraded or retrofitted older cars with r134a before with the ester oil and never had any problems with the refrigerant working with the old oil, as long as you put a few ounces of the new oil in.
The kit for r134a conversion from R-12 has everything you need to upgrade without removing all of the old oil.
Of course, in the early days of r134a conversion in the early 1990s there were people who recommended that you take the whole system apart, compressor, piping, receiver drier, etc. and replace the receiver drier and dump out the old oil.
In my opinion, this is a very expensive proposition, and good to excellent air conditioning can be had by following the R134a conversion kit instructions and installing 2 or 3 cans of refrigerant into your system.
This can be done by yourself.
Watch, if you're in California, you have to return empty cans of R134a to the store because they say that it is harmful to the environment and they want to keep track of it.
Good luck staying cool with R134a.
2helpful
2answers
Air conditioner compressor making a knocking noise while running.i read that oil needs to be put in it if so where and how or do I need to plan on replacing the compressor
Get a can of R134a refrigerant with sealant and oil and add with a hose.
Can buy at Walmart for under $30.
Buy the conversion from R-12 to R134a kit if you need to.
Sometimes adding a few ounces of oil will quiet the compressor but you have to try.
Compressor is probably a few hundred dollars to replace, so try the cheap solution first.
2answers
On my 2003 Chevy Silverado, the A/C compressor won't kick on. Just blows out warm/hot air.
The ac system may need freon added,if the system is low,or out of freon,it will not allow the ac compressor to come on.
Need replacement R12 refer and freezer compressors. OEM Americold compressors no longer available. URS 48 DT model should also work. Thank you.
You can use R134a compressors with the Poly oil in them and use R12 or R134a (flush the remaining old mineral oil out of the system first). Match your BTU requirements.
(Frigidair refrigerator R134a system) 3 months after a new compressor was installed it stopped cooling, it leaked. I found and repaired the leak. Then bought some automotive R134a it had dye,conditioner,...
The stop leak probably stopped up your cap tube system and the filter drier.You can try by replacing the filter drier, vacuum the system to 500 microns and recharge.The automotive 134a is the same as any other 134a.
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
