Question about Garden
My lawn mower starts, but won't stay running. I just used it a few days ago. tryed changing spark plug. checked oil, and full tank of gas
After you check airflow (i.e. cleaning up the air filter), check fuel flow.
I'm assuming the gas is clean and fresh.
Is the gas flowing from the tank?
Is the gas getting into the carb?
If yes, then the next step is to remove the carb.
Check the diaphram between the carb and the tank, this acts as your fuel pump. Is this diaphram in good condition? If not replace it.
While the carb is removed, clean all the little ports (jets) into the carb with WD-40 or carb spray-on carb/choke cleaner (automotive section of your local auto store). Blow it dry with compressed air (canned or from a air compressor). Replace any gasket so the carb doesn't have seepage when reinstalled.
It may sound a bit daunting, but its an easy job and may stores carry the necessary parts. Try WalMart, or auto stores, if they don't then a good hardware store should. Or, a lawn mower shop should have it.
Good luck, I'm rebuilding doing the same thing to one of my mowers this week. Piece of cake.
Posted on Sep 26, 2009
    Problem Solver:
  • 6 Answers
If it fires and seems like it has hesitation you can also try to sand the brushes just a little bit. A good rule of thumb is to place them a match book width from the magnets. Good luck Im gonna buy a new one :)
Posted on May 19, 2010
    New Friend:
  • 8 Answers
If your engine is a newer Briggs that has what appears to be a 1/2" nut at the bottom of the carburetor bowl, first shut off the fuel valve (if equipped) or clamp the fuel line to the carb. Then remove the 1/2" nut, which is actually the main jet, and pull off the bowl. Blast the holes in the jet with carb cleaner. It's a good idea to make sure that none of the holes is pointing toward you when you do that. Next, clean the bowl. It'll probably have some sediment and water in it. Then put it back together, making sure the bowl O-ring is clean and in good condition. Only just snug down the jet. Do not overtighten. Turn the fuel back on and get yer dang yard mowed before the neighbors start complaining. (In my experience this solves the start/stall issue on Briggs mowers every time, which is why I love the Briggs carb design.)
Posted on Apr 06, 2016
    New Friend:
  • 105 Answers
Most problems with small engines these days is using gasoline with alcohol in it. Most of the small engines are not designed to use this kind of gasoline and the alcohol is very corrosive. The smallest circuit in the carb is the idle circuit and it is often blocked by the corrosion and needs to be cleaned out typically with a very small wire to open it. After that purchase gasoline without alcohol in it. I typically only put enough fuel in the tank to do the particular job that I am doing and then let the engine run until all the fuel is gone out ob the carb. Mostly I do this in my weed eater and my leaf blower and do not leave any fuel in my generators.
Posted on Apr 05, 2015
    Champion:
  • 236 Answers
What engine is it??
Posted on Mar 20, 2015
  • Garden Master
  • 3,828 Answers
If after that checking still no better ..suspect the coil
Posted on Mar 19, 2015
    Guru:
  • 479 Answers
This is likely to be a fuel starvation problem.
Fuel is fed from a reservoir called the float bowl. This works pretty much like a toilet cistern with a float to cut off flow once it fills. Once the bowl empties and doesn't refill due to a blockage, the engine will cut out.
Clamp off the fuel line or turn off the fuel tap. Remove the bowl, and check fuel flows freely. If it doesn't, there is a blockage in the fuel line which you need to trace.
Another scenario is that the main fuel jet is blocked or semi-blocked. This can cause the engine to run ok when idling (since the idle jet is ok and not much fuel is required), but cut out as you throttle up. This is because more air is sucked in, but not enough fuel is drawn from the main jet due to the blockage. So the mixture is too weak and the engine stalls. The jet can be cleaned with compressed air or ideally a carburetor cleaning aerosol.
See my comprehensive guide for getting stubborn lawn mower or other small engines to start:
Why Won That Lawn Mower Start Small Engine Troubleshooting
my lawn mower starts, but won't stay running. - 2965177-xoiwilb1fryjy1fsdwxqyhcm-4-1.jpeg
    New Friend:
Sounds like it's not getting fuel. It starts initially because you have the choke on, but when you open the choke you are getting inadequate fuel. I've found most of the time this is a carb problem - there is a tiny particle lodged in the needle valve which keeps it from opening. For me, most of the time, taking the carb off the machine, take the bowl off, and poking all the holes you can find with small thin wire (and spraying with carb cleaner) will solve the problem.
Posted on Sep 20, 2014
    Scholar:
    New Friend:
  • 65 Answers
If it starts and stops it sounds like it is running out of fuel so try something even simpler check the filter in the tank and clean it out also check the tank cap vent sometimes it will need a poke with a piece of wire if it is simply offset holes so the fuel does not create a vacuum & stop fuel running later model caps have valves in them clean and then check the valve operation
  • 157 Answers
Check the air filter for being stopped up also check the fuel filter for blockage .
Posted on Sep 19, 2009
  • Marjorie Buerkle
    Marjorie Buerkle Oct 28, 2013
    ok but this just happened AGAIN. I took it to a repair shop that time. Now what?
SOURCE:
Lawn mower instructions why wont it work
check for spark at plug if spark at plug then squirt some starting starting fluid in carb see if will start it should run long enough to burn out starting fluid if does check for water in gas if is drain tank and carb bowl put in fresh gas not and repeat not old gas you were using strat lawn mower if still dosnt start rebuild carb and add and additive called seafoam to the gas this is good stuff follow instrution on bottle
Sep 02, 2014 | Garden
Motor mower wont start
By tipping a 4 cycle motor on a lawn mower or any equipment, you have all the oil and gas running into the combustion chamber and sometimes the oil and WATER will get into the tank. It will need too have the spark plug removed, the engine turned over with the starter to blow the oill, gas, and water out of the cylinder(s), the plug should be either dried and gap reset, and the gas tank drained and FRESH gas put in it. Replace the spark plug prime with just a few drops of gasoline in the carburetor throat and restart and let run to dry evrything. NOTE: An oil change is recommended, too!!
Jan 14, 2014 | Garden
Obvious solutions won't start Lawn Mower!!!
Sounds like it's a fuel issue.
After the Carb rebuild, you put gas in the tank and started it up immediately. and ran it only 30 seconds.
If you look at the gas tank now, is it empty? Is there gas flowing out by the air filter? You sounds mechanically smart, just wondering if you messed up something with the carb rebuild and gas is flooding up into the carb. Check the Oil again, is it overfull from gas getting into the oil?
Jul 27, 2013 | Briggs & Stratton Garden
Ive replaced my transmission on my walk behind lawn mower it was almost upside down for 2 days ive replaced the gas and oil but it wont start
The gas and oil weren't in the mower when it was upside down were they?
If that's not the issue, then the problem could lie in the fact that neither tank was fully drained before being put upside down. What happens is that the oil and fuel mix and will drain into the wrong area.
My best suggestion would be to leave the mower upright for a few days before trying to start it If need be, drain the oil and gas and let both tanks dry out completely before refilling.
Clean the spark plug and change the filter.
If none of these ideas work, then you will need to take your mower in to be serviced.
Aug 13, 2011 | Troy Bilt 5.5hp Self Propelled Mower
Lawn Mower will not stay running then will not restart
I think we all understand the frustation penaone.
I noticed u didn't clean the fuel tank, water, dirt, and rust in it can give u problems. But u need to clean the lines and carb. again also. One of the kids filled my mower gas tank with driveway gravel once, and after I cleaned things out, the mower never run so good. Also your spark may be grounding out somewhere before it gets to the spark plug. Check for a bad spot in the wires from the magneto. Some of that may be behind the flywheel though.
ballping
Jul 28, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
My bolen push mower won't start, it worked two weeks ago. Gas and oil are full. where do I go from here, change spark plug?
see if it has spark. try to trickle a little gas into where the carburetor is and see if it will atleast fire.
May 01, 2010 | Poulan "Poulan" Push Mower
Poulan 6.75 Lawn mower will not start
Remove spark plug, clean and dry. Replace plug. Remove air filter. Spray WD-40 into carb opening; one second blast. Turn over engine, (pull handle). Engine should start briefly and run for 3 seconds.  If not, you are not getting spark to spark plug. If engine starts, you have a dirty carb and you can buy a rebuild kit from manufacture.
May 02, 2009 | Poulan Pro " Pro" Self Propelled Mower
My lawn mower doesn't start and when it does, smoke comes out of exhaust
you may need to change the oil and/or empty the old gas and replace it with new.
This thing happens when you don't take care of your lawn mower for too long.
Sep 01, 2008 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
22,588 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
