Turning on sound on Ultronic TD00552 Alarm Clock...all seems fine but no sound
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 3 Answers
SOURCE: ultronic lcd clock with a stylus tucked in back of clock
This thing set under my bed, lifeless til I was looking for something else and decided it was time to get this clock working!
(Use the stylus pen for best results) After putting in two fresh batteries (or hit the reset button if your batteries are fresh). This will reset the clock and the 'clock' icon in the upper lefthand corner will be blinking. Now press and hold the display area where the hour of the day is displayed. The entire time will start blinking. Now start tapping on the blinking hours to increment the clock slowly to the correct hours (it will cycle all the way thru military time and regular time, so choose what you desire). Press and hold with the stylus to increment quickly. Do the same with the minutes, that are blinking too. When time is correct, tap the 'clock' icon once. The 'clock' icon will still blink, which I believe is correct operation.
To set the date, tap on 3rd icon down from the top left (it looks like a little calendar). This will put you into the date section of the clock (if you do nothing, it will cycle back to the clock, after ten seconds, as a default). Before it cycles back to the clock, press and hold with the stylus pen right below the word 'DATE', until the the entire displayed date starts blinking. Tap the first two digits of the year to go down in years and tap the right two numbers of the year to go up in years. Tap on the month number to increment; do the same with the date number. When all date entries are correct, either tap the 'calendar' icon, or let the clock sit for ten seconds: it will cycle back to the clock.
I guess you can set the alarm in a similar method.
Hopes this helps!
ExitKC
Posted on Feb 28, 2009
SOURCE: Need to set an Ultronic clock
Press the time (current time - numbers) to get to the date mode. Then hold-press "SET" to set it.
Posted on Aug 22, 2010
SOURCE: ultronic WS-9 radio/clock/calculator is there a light?
need a manual for a Ultronic clock radio calculator model WS-9
Posted on Jun 24, 2011
Setting an ultronic touch screen alarm clock
TD00552: 12 hr--military time toggle= tap time set button. Set time= hold down time set button till up & down arrows show on r & l sides; set hour, tap time set button, then set minutes, repeat, seconds, repeat. Date change= tap hour if needed to show day & month; then hold set button on left till up & down buttons show at edges of screen. Up/down buttons to set year on lower right screen, tap set again to change # day of month, tap set again to change month, and the day will correct itself. Change temp c° -- f°= tap alarm button if needed to display temp b them tap set button next to it to change temp scale. Alarm- off/on= tap screen button if needed to show alarm time; tap alarm set button next to it- it will toggle on/off. To set= with alarm time showering, hold down alarm set button till up/down buttons show; follow same process as above.
You are all welcome ??
Jul 01, 2017 | Televison & Video
Where can i purchase an ultronic weather=clock
You can purchase them on ebay or amazon,
you can get them on www.alibaba.com -see the link
Ultronic Weather Station Clock Ultronic Weather Station Clock Suppliers
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/bryan_4d4c18793378ea97
Dec 12, 2015 | Audio Players & Recorders
Ultronic td552
Press upper right box 'alarm' until alarm time shows, then press 'set' button and it will toggle between 'off' and 'on' for the alarm.
Jul 01, 2013 | Audio Players & Recorders
Have a new ULTRonic Global clock. Came in a box, well packed but apparently no setup instructions. Have been able to set the clock after much guess work. Temperature, Humidity and trend seem to work....
This is for Ultronic LCD clock/weather gadget.
keywords (from display)
Ultronic forecast week day humidity temperature trend comfort level
- DOWN = toggles F/C temp
- UP = toggles alarm
- MODE = selects date/time display
- hold down MODE to enter "set" mode for data currently displayed
- use momentary MODE to choose target item
- use UP/DOWN to change item
Nov 01, 2011 | Watches
Ultronic Touch Screen Thermo Alarm Clock TD552 Desktop Model
This may be helpful, it's how I set mine.
1) Remove battery cover
2) Remove batteries
3) "Set" the clock and battery cover into the trash can.
There you go. No more problem !
Mar 15, 2010 | Computers & Internet
Ultronic WS-9 radio/clock/calculator is there a light?
Dec 15, 2009 | Audio Players & Recorders
Feb 19, 2009 | RIM BlackBerry Pearl 8100
24 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
