Mitshubishi model wd73c10 changed lamps giving a code of 6red lights 1 orange tv sound turns on no picture then tv shuts down
6ya staff
SOURCE:
Anonymous
  • 7 Answers
SOURCE: hdtv-dlp has no sound or picture
This sounds like an o-so familar problem. It sounds like the Switching IC or the MICOM has failed
Posted on Nov 10, 2006
ctf1800
Cary Farah
  • 4402 Answers
SOURCE: mitsubishi dlp does not get picture
the plug the connects underneath is not connecting right you have to get at the plug and seat it correctly
Posted on Dec 08, 2007
smilemaker
Kanth raj
  • 790 Answers
SOURCE: "Fan lock"
Use the below link to locate ur nearest service centers ...
its an hard ware cognitive factor u alone cant rectify it ..
http://maps.jvc.com/cAscList/index.asp
Posted on Dec 23, 2007
Anonymous
SOURCE: Has Sound but no Picture and shuts down
I have the same tv and the same problem happened to me (Actualy twice). It turned out to be the color wheel motor. thats what the clicking noise is.
Posted on May 15, 2009
Anonymous
  • 556 Answers
SOURCE: Mitsubishi tv model # wd-52527, lamp light flashing,no picture.
I would say so.
Posted on Aug 18, 2009
Mitshubishi WD-62327 TV will not turn on and no sound. TV made a interference sound and shut off. Tried to turn it in the morning still nothing. Replaced lamp/bulb still nothing. Red light is on (not...
If you have a voltage meter there are some things you can check.
Unplug the unit and remove the back cover of the set. Then Plug the unit back in.
You will need to tape down the lamp safety switch in order to do these tests.
Here are all the failures that would give you a lamp error and what to check.
Cause 1. Unit powers on and works properly for a while then shuts off with a red lamp led(lamp error). Suspect bad lamp and replace.
Cause 2. Unit does not power up correctly and you have red lamp led(lamp error). Check the lamp enable line at connector J14 on the back of the light engine. If pin 6 does not switch to 5 volts after turn on, but your 12 and 5 volt supplies are good, then suspect a defective light engine.
Cuse 3. At power on the lamp turns on and off 3 times and then the unit shuts down with a red lamp led(lamp error). You have a defective light engine.
Cause 4. Unit does not turn on correctly and you have a red lamp led(lamp error). Check for 12 volts at connector J9 pin 4 on the light engine. If voltage is missing check for an open fuse F9A09 on the power supply board. If it is open, then you need to replace the fuse and you still have a defective light engine.
Cause 5. Lamp enable line at connector J14 pin 6 on the light engine does go to 5 volts at turn on, but does not drop back to 0 volts after 5 seconds, but your 12 and 5 volts supplies are good then you have a defective light engine.
Cuase 6. Check for 5 volts at connector J9 pins 1 and 2 on the light engine. If low or missing check Capacitors C9A37 and C9A38. Values are 3300MF/10V. Replace capacitors if defective.
This is all I have and I wish you luck.
Mar 20, 2013 | Mitsubishi WD-62327 62" Rear Projection...
TV SHUT OFF IN THE MIDDLE OF A SHOW. IT IMMEDIATELY TRIED TO TURN BACK ON BUT JUST CYCLES ON AND OFF WITH NO PICTURE. SAMSUNG MODEL-HLT5076SX/XAA
Sounds to me like the lamp may have failed on this LCD projection tv, You may have heard a pop from the tv. if so the lamp is gone. On the side where the lamp installs you will find a lamp code # orange tag. This BP96-***** is the lamp #. Ebay that number with niosales. Best pricing, free shipping excellent quality lamps assemblies.
Jul 09, 2011 | Televison & Video
My Misubishi WD-52631 DLP TV is off sudenly. I turn it on again, but no picture, no sound, nothing happened. I reset it, nothing happends. the green power light blinks for a while, then shut off itself....
Tv LED "LAMP" light indication is blinking?And ur tv projection lamp inside ur tv been used like 1 1/2 or 2 years.Yes.The tv projection lamp require changing,tv projection lamp life are ended.
Apr 19, 2011 | Mitsubishi WD-52631 52" Projection HDTV
I have been given a used Samsung TV without manual and have no idea how old it is or the exact size of this particular TV however, it is bigger than a 42''. I have written down the model code, serial...
The front panel LED light indication "LAMP" flashes?Change the the tv projection lamp or LED lamp first,see what happen?Than go from there?Tvs with "LAMP" LED indication light flashes,tv 1 1/2 or 2 years old use like 4 or 5 hours a day.The projection or LED lamp or bulb,inside life span is over.Require changing LED lamp or projection bulb.
Sep 10, 2010 | Samsung Televison & Video
Tv shutdown
check your lamp door interlock switch.
Jul 31, 2010 | Mitsubishi WD-65733 65" HDTV
I have a wd65733....When I turn the set on, I get a picture then about 30 seconds later it will shut down giving me a steady orange light
CK Lamp and Lamp Fan, Mats has Lamps for $99.00
other companys want 273.00 1-800-628-1118
Encompass Parts Distribution has Free service Manual for this Model, you can print out online.
Sep 13, 2009 | Mitsubishi WD-65733 65" HDTV
Light engine
hold menu and input or device button at same time for 5sec. Let me know what blinking code you get. 3-2 6-1 etc.
May 25, 2009 | Mitsubishi WD-62531 Projection Television
No picture or sound mitsubishi 62525
Capacitor failure is the most likely scenario the FMT ans Signal PWB would cause the picture interference and the power pwb would cause the lamp light to turn red and give a 34 code when the device/ input and menu buttons are pressed in together and held for five seconds. That chassis has issues with every board in the chassis having failed capacitors you can get repair kits for the V26 chassis at the follwing link that come with instructions. Your model is the V26 chassis. Heres the link.
http://servicemanuals.vstore.ca/
Jan 25, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Hdtv-dlp has no sound or picture
Nov 10, 2006 | Samsung HLN467W 46" Rear Projection HDTV
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
