Question about LG Televison & Video
LG 50PC5D scrambled picture for a couple of minutes until warmed up then seems fine except during commercials or programs with overlays and it jerks/stutters the picture.
6ya staff
SOURCE:
ctf1800
Cary Farah
  • 4402 Answers
SOURCE: Mitsubishi VS-50707 - Scrambled picture
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Posted on Dec 15, 2007
abhishek33
ABHISHEK.C
  • 1239 Answers
SOURCE: My 42 inch plasma has black distorted picture
hi
its cathode ray tube problem or the colour wheel...check that both please.....
thank u,,,,,,
Posted on Mar 07, 2009
Anonymous
  • 147 Answers
SOURCE: black screen
first try the address board or buffer board.if this
does not repair it,the panel is defective.
Posted on Jul 17, 2009
Anonymous
SOURCE: remove stand from LG 50PC5D
There are four screws in the back of the TV above where the stand is. Inbetween the screws is a metal handle that pulls out. These four screws need to be removed and the metal handle pulled out. Then the TV will come off the stand.974336c.png
Posted on Oct 09, 2009
Chi Chu
  • 8457 Answers
SOURCE: LG 42LH30 Audio Problem (Background Buzzing)
Ur power supply board.Transformers have have high voltage gap.This problems must take the tv aparts put some glue arond the transformers,sometime solved this problems,or must replaced all the trnsformers make the humming noise.Brand new tv take it back,where u bought it get a replacement or call the Manufacture help to fix the problems or replaced the part that cause the problem.
Posted on Feb 08, 2010
Why does my LG tv seems like it need to warm up before it will accept HDMI signal?
Sounds like a capacitor fault. They can be intermittent when cold, but will work okay when warm. Eventually though they will fail.
This is your advance notice to get the set either repaired by the manufacturer or a local TV shop.
Sep 06, 2014 | LG 42LG50 42 in. LCD HDTV
My TV pictures scrambles after warming up
Check and replace all the electrolytic capacitors.
Aug 28, 2012 | Televison & Video
Lg 50pc5d
If picture only one side or only top or bottom set uses two boards to drive the screen, either one of them is bad or the actual display panel itself--it is the entire screen unit where the picture is displayed.
May 25, 2012 | LG 50PC5D Television
Snowy white picture while on cable.
Maybe a tuner problem--considered hooking up whatever you use for signal to the rear av jacks? bypass the problem?
Apr 06, 2012 | LG 50PC5D Television
I have a Mitsubishi VS-55707 and I have a couple of problems. first it takes 5-10 minutes to warm up (scrambled picture) after that it works fine, but its getting longer to warm up. Second every once in...
i had the same problem. im sorry to say that you are out of luck and you tv is on the way out. i had the same problem and spend $100's of dollars to have people come and try and fix it to no luck. sorry
May 23, 2010 | Mitsubishi VS-55707 TV
Picture is scrambled until it warms up. Can play DVD without any issues, but all other video inputs are scrambled for 30 - 40 minutes.
unit has a bad hyper module,NLA thru toshiba.try contacting tristate module or pts to see if they still rebuild them.toshiba part-23786198,MVPU13,PD0264A
you mite have to search to web a bit to find one if they dont rebuild them anymore.
Sep 29, 2009 | Toshiba 42H81 42" Rear Projection...
Turns on But No Picture and No Sound
sounds like it could be a cabling issue, try replacing the cabling (if you have another tv, you can borrow the cabling before purchasing new set of cabling)
Apr 04, 2009 | LG 50PC5D Television
Scrambled picture
I have the same problem here as well, except that it has been happening so long that now it doesn't get completely clear. The picture was great at one time :-(
Jul 07, 2008 | Toshiba 50H81 50" Rear Projection...
Mitsubishi WE-52525
. Suspect the FMT PCB part # 930B924002 when set is warm.
Jul 31, 2007 | Mitsubishi WD-52525 52" Rear Projection...
LG Plasma TV 50PC3D
The TV should be under warranty. Send back. Sounds like the panel is faulty (half the value of the set).
Feb 06, 2007 | LG 50PX4DR 50 in. Plasma TV
Televison & Video Logo
Ekse
RONALD CARTER JR
