Televison & Video Logo
Jacqueline Carrisosa Posted on Oct 15, 2019
Vizio bluray model vbr220 : Ive never used a parental passcode and is now asking for one. Cant watch movies please help
Helpful Friend
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 4 Answers
  • Posted on Oct 31, 2019
Helpful Friend
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
0
Helped
1060
Points
5 Related Answers
Anonymous
  • 432 Answers
  • Posted on Jul 21, 2007
SOURCE: Parental Controls feature
Hey Aurora, After you put your password in, go back and change the password using blanks spaces. Then it should reset to 'parental control off'. Let me know if this works. Some Sanyo models are different to reset.
A
Anonymous
  • Posted on Apr 03, 2008
SOURCE: PLEASE HELP, PARENTAL LOCK CODE ESA DVD/VCR COMBO UNIT
this is a new thing on dvds. must reset.
Anonymous
  • 15 Answers
  • Posted on Apr 10, 2008
SOURCE: over ride the parental control level
Ok first try 0 1 2 3 because that is the preset code for the ps2 or if that dont work insert any dvd movie, go to setup and access the parental control settings(press select) When asked for your code enter "7444"; It will prompt you again to type in your password. Type "0000" and then scroll down to the movie rating options and choose "off". Hope it helps you out!
Anonymous
  • Posted on Oct 25, 2008
SOURCE: Parental Control V chip has been activated.
on my Sharp 36R-s400. Go to menu , then parental control. When dispaly asks for secret number,
press and hold volume up and channel down simultaneously until message is cleared.
This turns off parental control and clears the password.
Anonymous
  • Posted on Dec 07, 2008
SOURCE: PS2 PARENTAL CONTROL CODE
This is the only way to turn "off" parental control lock on the custom setup screen.
1) turn off ps2 with no dvd in drive.
2) turn on ps2 and insert dvd in drive.
3) when it asks about parental password, choose 'yes'.
4) when prompted for password, press 'select'.
5) the prompt will change and say 'delete password'. enter '7444'.
6) enter a new password (0000 works).
7) registration complete, dvd will start playing.
8) once the movie starts, press 'select'.
9) click the 'stop' icon.
10) click the 'stop' icon again (the icon must be gray even when you have it highlighted).
11) navigate to 'custom setup' ('select', setup icon, custom setup icon)
12) move to parental control option, press right directional button, enter password (0000).
13) move down to 'level'.
14) move up to desired level (off is at the top).
15) click 'x'.
16) go back to 'select' menu options, and press 'play'.
17) while movie is playing, eject disk and remove dvd.
18) turn ps2 off using switch on the back, keep off for five seconds.
19) turn on ps2, put dvd back in.
20) happy dance. ;)
1helpful
Do I have to have an internet connection to play only DVD on a Vizio vbr220?
You should not no. Most players only need to be connected to the internet to do updates for the device and/or for bluray playback codecs. A regular dvd is a standard format and should not require any update to playback.
I am a member of netflix how can i watch movies on my tv
You need a connected tv that has an app for Netflix or buy a dvd/bluray that has connected tv apps built in. I have a Sony bluray and am able to watch netflix, amazon Prime video and youtube on my tv through this bluray
Both hdmi ports dont work Vizio 50" model P50HDM
Reset Vizio TV default:
1. Press the MENU button on the remote. The on-screen menu is displayed.
2. Use the Arrow buttons on the remote to highlight the Help icon and press OK. The Help menu is displayed.
3. Highlight Clear Memory (Factory Default) and press OK.
4. Enter your parental control passcode. If you have not yet set up a parental passcode, enter the default, 0000.The TV displays, "Are you sure you would like to Restore Defaults? This will erase any custom settings."
5. Highlight Yes and press OK. The TV displays "Memory is being cleared. The TV will reset shortly."
6. Wait for the TV to turn off. The TV will turn back on shortly afterward and the Setup App will begin.
1helpful
Audio does not match actors mouth , like an old godzilla movie this is second one
Have you connected the Blu-ray player to an AV receiver. If so you can go into the setup of the Receiver and adjust the Lip Sync in some receivers its called Timebase Correction. It will be given in milli seconds. This adjustment allows the use to delay the voice in milliseconds to sync with the picture. Maybe even your Bluray player setup might have this feature. Mostly it is done by the Receiver.
Lost password cant watch movies on playstation 2
1. Insert a DVD Movie into the PlayStation®2.
2. You should receive a message informing you that the Parental Level has been set, and asking if youý"d like to allow the disc to play. Highlight "Yes" and then press the X button.
3. A new window will appear asking you to temporarily change the Parental Control to a different level. Again, highlight "Yes", and then press the X button.
4. Another window will appear asking you to enter your Password. Above that window are numbers (0-9).
5. Do not enter your password, but instead, press the select button on your Controller. This will change the text in the window from "Enter Password" to "Delete Password".
6. Using the numbers above the window, input 7444. If successful, you will receive a message stating "Deletion Complete".
7. Press Select. You will now be asked to register a new password. Please select a four-digit code of your choosing.
8. You will be asked to confirm your password selection by inputting the same code once again. If successful, you will receive a message stating "Registration Confirmed".
9. Now you need to turn off the password altogether. The movie should of started playing by now. Press select and chose Setup. Go to the parental control "tab" and set the level to "off".
10. Now you should be able to watch any movie
All credit for this write up goes to the member POST (revised by UnhappyKlown3). hope this helps please remember to vote
5helpful
2answers
I forgot my pass code for the rating for movie watching, How do I reset it?
When you get to the screen where it ask for passcode press the select button on the controller, it will take you to a screen to delete the passcode enter 7444 then it will prompt you for a new passcode and you can enter something you can remember. After you set new passcode you can go into parental controls to turn the feature off if you like.
Brand new audiologic dvd player, asking for password when you try and play a movie. Any idea what the default password is?
the default passcode for parental management is usually 0000, 9999, or 3308
the parental management system is there to prevent minors from watching unsuitable content.
1helpful
2answers
Over ride the parental control level
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
