SOURCE: fujifilm finepix j10 camera drivers on vista??
http://www.fujifilmusa.com/support/ServiceSupportBrowse.do?prodcat=877127&sscucatid=664260
click this link directly to get the drivers and download it.
SOURCE: fujifilm finepix f40fd
An update to the initial posting. As a warranty service provider, I can state that physical damage as a result of mis-use is NOT covered under warranty. Lens problems caused by dropping the camera are considered mis-use and are not covered. There is a good posibility that the lens assembly is just out of timing and can be rebuilt, but the cost to do this will not be paid by the manufacturer.
I don't want you to believe that this repair will be for free as it will not.
Regards,
Dan
SOURCE: I have fujifilm finepix s9600 and need the
when you connect your camera with the pc the camera will probably appear as a seperate drive on your computer. for example if you have a hard disk C: and a dvd driver named D: check to see if a new external disk appears as E: which will contain the folder of your pictures on your camera.
you can also check here
http://www.fujifilm.com/products/digital_cameras/s/finepix_s9600/index.html
Testimonial: "Thank you found it.. excellent service.."
SOURCE: fujifilm finepix printer ip-10 driver WINDOW 7 64 BIT
You can download the Fuji printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :-http://www.drivermanager.com/en/drivers.php?Brand=Fujifilm&Logo=fujifilm&gclid=CNfbvPab1K4CFQYdpAod5ma8bw
SOURCE: I need to download a driver for my FinePix JV300
You don't need a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
