SOURCE: Newly set-up Brother color laser printer displays drum error.
The slides you are moving are for the drum units, you could try using canned air to blow in the same area that the sliders slide across, if that doesn't help you may need a new drum unit..
SOURCE: Our brother printer is saying drum error slide
You need to open the printer access panel. Inside, there's the "drum", which is secured with plastic tabs.
http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/faq/faq/000000/000300/000016/faq000316_005.html?reg=us&c=us_ot&lang=en&prod=mfc9440cn_all
SOURCE: Brother 4070 CDW Drum Unit Error
The green tabs that you have to slide are under the color cartridges, so remove the three color cartridges and you will see three green tabs, to slide the tab across the wire you have to first open the translucent plastic wire cover, then slide the green tab across the wires and return it to it's original position, close the wire covers, replace the color cartridges, and reassemble the printer. All the Best
SOURCE: brother printer 4070CDW drum error slide green
Open up the printer and slide the green tabs to clean the drum chargers
