Garden Logo
Juan Jirau Posted on Oct 15, 2019
I have a m2510, When pull the cord, it doesn't recoil or return, Tried several times to remove front housing, but I don't know how to remove the shaft or spacer and then access to the recoil starter.
usedtotruck2
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 10 Answers
  • Posted on Oct 15, 2019
usedtotruck2
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
10
Questions
0
Helped
6779
Points
14
If that is an MTD m2510 weed eater you're asking about, you have to remove the engine to access the starter assy.
4 Related Answers
Dwain Pippen
  • 377 Answers
  • Posted on May 26, 2009
SOURCE: starter cord not recoiling
To get to the starter rewind, you have to pull off the clutch hub and clutch. Without the proper tools, it would be best to take it to a shop. Dwain
Anonymous
  • 70 Answers
  • Posted on Oct 04, 2009
SOURCE: How to change the pull starter cord.
drill out rivets then re-rivet or use self tapping screws
vincob
vince janis
  • 718 Answers
  • Posted on Nov 25, 2009
SOURCE: My recoil starter will not pull back the recoil
Go to smalleng.com they have free how to videos for just your problem, check it out it's a pretty cool website.
philwalker78
Phil Walker
  • 610 Answers
  • Posted on Jun 27, 2012
SOURCE: gain access to the starter pull cord pulley efco 220 brush cutter
Hi, you have to undo the clutch spider off the crankshaft but you will need to lock the piston with a piston stop to do this. Regards Phil.
1helpful
My Husqvarna 128LD pull cord doesn't engage
Possibly the recoil starter pawl's on the inside of the recoil housing not engagning with the flywheel.
Repair of pull start to garden blower
To replace the pull cord line:
If your pull cord is still attached to the grab handle, it's likely your spring is still wound. Follow this if this is the case, purchase rope of the correct length (or cut) and the correct diameter at your local lawn/garden store, then:
1. Disconnect the long drive shaft by removing the small set screw and the clamp - pull the shaft out of the engine body.
2. Remove the recoil assembly (About 5-5 torx bolts). You may need to disconnect a wire to the kill-switch at this time.
3. Pull the cord until it stops and use a small piece of wood acting as a wedge to jam between the recoil and the housing.
4. Cut the line and pull the knotted terminating end from the hosing.
5. Keep the wedge tight so it does not spin back. If this happens, you will simply need to rewind the spring back (about five turns) and re-wedge it.
6. Feed line through the recoil housing and into the recoil. Pass line through the hole in the recoil and knot the end. Trip to about .25 inch tail. Pull the rope through the grab handle and single or double knot this.
7. Remove the wedge and allow the spring to pull the rope back into the recoil.
8. If it does not completely recoil, either your rope is too long or you will need to add a "wind" to your spring buy removing the line and wind back 1 more turn. Retry.
Sep 25, 2010 • Garden
My craftsman pull cord broke on my weedwacker
Remove the tube that holds the flex drive from the end of the crankshaft. Lossen and remove the front cover. Remove the throttle cable from the carb. Remove the kill switch wire from the coil module. Remove clutch housing. Remove clutch, Remove flywheel. The recoil unit mates with the bottom of the flywheel and all the aforementioned parts are on the front side of the engine's crankshaft. Once you get the recoil unit off, you remove the old cord and turn the unit several times to "preload" tension on it. Insert the new cord into the guide holes and tie knots to lock it in place. The pull handle must be attatched too or when you let the recoil draw in the new rope, it will keep going and all tension will be lost. Reassemble all the above and good luck
On my 17" straight gas trimmer the pull cord will not retract, how can l fix this please, thanks
Remove the tube that holds the flex drive from the end of the crankshaft. Lossen and remove the front cover. Remove the throttle cable from the carb. Remove the kill switch wire from the coil module. Remove clutch housing. Remove clutch, Remove flywheel. The recoil unit mates with the bottom of the flywheel and all the aforementioned parts are on the front side of the engine's crankshaft. Once you get the recoil unit off, you remove the old cord and turn the unit several times to "preload" tension on it. Insert the new cord into the guide holes and tie knots to lock it in place. The pull handle must be attatched too or when you let the recoil draw in the new rope, it will keep going and all tension will be lost. Reassemble all the above and good luck!
Please vote on this solution.
The pull chord is jammed i cannot remove the part that the cord is wound on in order to unwind it....help please
Here is a condensed version of getting to the starter/recoil unit to inspect or repair.
How to change the pull cord on a 32.. weed wacker
4helpful
Howdo I fit a new pull start cord on a ryobi 25cc
remove the plastic housing to gain access to the recoil. Pull the cord slowly all the way out,this will cause the spring to wind up.Clamp the recoil wheel so it will not return to its original position,be carefull the recoil has tension on it not remove the old pull rope and thread the new one in and thru the hole of the recoil tie knot.pull on the cord to take tension off and at the same time remove clamp. Slowly allow the recoil to wind the rope in and reinstall on unit.
2helpful
Broken recoil start on tecumseh 6.5 hp
broken cord? remove bolts holding recoil housing.lift housing straight up,you may have to wiggle it a bit.turn housing over,remove any cord thats left,note how & where it connects to the spool.wind the spool [and consquently the spring under it]in the direction the cord would turn it as pulled when starting.hold spool tight.thread new cord through hole in housing.let spool turn back just enough to attach new cord.hold cord & housing,let spring "re-coil" cord slowly.check for smooth operation.replace housing.you may need to pull cord slightly to align 'square' shaft w/hole in spool.only after you are satisfied with the operation of it adjust length of cord by pushing excess cord through the handle,tie a new knot,then cut off excess,if any.
Sep 21, 2009 • Garden
2helpful
Recoil not returning rope when pulled
There is a spring inside the pull cord housing that makes the cord come back in, it probably undid itself, remove the housing cover and rope assembly and you will see the spring, you need to retighten it and place everything back. hope this helps
Top Garden Experts
Jay Finke
Jay Finke
john h
