Defy washing machine E01 error
What does an E01 mean on a Defy washing machine
An E01 error code on a Defy washing machine typically indicates a problem with the door or lid. This could be caused by a malfunctioning door lock, a problem with the door seal, or an issue with the lid switch. The error code may also indicate that the door is not properly closed or that there is an issue with the wiring or connections related to the door or lid. It is recommended to check the door lock, door seal, lid switch, and wiring connections
Two different ideas from Bosch, either control board or heater element, temperature thermistor. As it fails at the rinse stage where the water is hotter, I would check the latter, or just call for service and get it correctly diagnosed and fixed. If you want to try some things, check connections to the main control board and to the heating components.
The E01 fault code means that the dishwasher has suffered a power module failure.
The programming of replacement power modules E01 up until E05 has been locked down by Bosch so in the event of an error code of this type it's recommended that you contact a Bosch approved dishwasher engineer.
It seems like main motor pump or main control problem
do step by step troubleshooting procedure to eliminate working parts until you could detect defective part or parts
I have the same problem, suspect it happen after I installed bloom berg anywhere. When I run bloom berg anyway, it prompt your device is jailbreak and cannot be trusted to run securely, after that the bllomberg for iPad does not load anymore.
The thermostat may temporarily lose calibration due to temperature changes resulting in an E01 error message on the display. Repeat the following steps to reset the unit.
1. Unplug the unit from the wall socket for approximately 10 seconds.
2. Plug the unit back into the wall socket.
3. Press the POWER button once. Within one second, press the COOK button once. The unit should now be rese
