Question about Casio Watches
Watch stem release on Casio LTD 1035 where is it located
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: Casio wrist watch
I have a parts watch.
Posted on Apr 15, 2009
Anonymous
  • 98 Answers
SOURCE: resize DKNY 1035 Wrist Watch band
Could be a number of different ways. Some newer watches have multiple clasps that make it easier for you to adjust it yourself. Check the bottom of the band for extra clasps.
Without seeing the watch I have no idea what type of links you have. I suggest taking it to a reputable watch repair shop and have them adjust it for you! It will save you the frustration of having to search for a small screw or pin if it should fall on the floor!
Posted on Jan 10, 2010
Where do you look for release of. The Stem if there is no small screw
There is a couple of different methods to release the stem,
1. By a screw, note if a screw only 1.5 turns only
2. push button near the stem, push button in and release the stem
3. pull the stem out and a little lever will be seen by the stem, press that and the stem will come out
4. if quartz, will have a hole with a small arrow pointing to it, with a needle insert into the hole to press the lever inside.
Otherwise need more information on the type of watch movement
Nov 29, 2017 | The Watches
I need to change the date
Changing the date for the FT500WVB watch is easy. Just pull out the stem of the watch to its first stop. Then turn the stem counter clockwise a couple of twists and the displayed date will increment (that is increase) by one day and you will hear a little click. Keep twisting the stem counterclockwise and the date will increase by one each time with a little click. Stop when you reach the correct date and push the stem back in to its fully seated rest position. Note- be careful not to change the date when the watch displays a time between 9pm and 1 am as setting the date in this time range may cause the watch to increment the date at noon rather than midnight.
Note also that if you want to set the time you just pull out the stem to its second stop position and twist the stem to advance the position of the hands of the watch. Then when the time is set, push the stem back in to its lowest rest position. So remember- first stem stop sets the date and second stem stop sets the time. That's it.
Mar 25, 2014 | Casio Forester FT500WV-3BV Wrist Watch
How do I remove the back of this watch?
I have seen other burberry watches and the back should pop out .
1- Locate a very small tab or recessed area on the edge of the back cover 2- Pull out the stem, which releases the back on some watches.3- Get a small flathead screwdriver it needs to be a thin inflexible tip 3- Very carefully slide the blade under the tiny metal protrusion on the back cover (or across the length of the recessed area, depending on which type of cover your watch has). 4- When you replace the cover, make sure you line up the stem slot on the cover with the stem of the watch. This information is on wiki: http://www.wikihow.com/Pry-off-a-Watch-Backing-Without-Proper-Tools
Feb 19, 2013 | Burberry Authentic BU1321 Womans Swiss...
I dont know how to set the analog time on my watch because it only has four buttons and no winding stem
Press the "mode" button (bottom left) until the display says "HS" then press either the top right or bottom right button (depending whether you want to advance or ****** the hands) until the hands point the correct time.
When you have finished, press the mode button until the display returns to normal.
If you have any problems, (I have given you instructions that apply to my Casio, which is a different model, then you can get instructions for your model from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Dec 24, 2010 | Casio G-Shock G511-1AV Wrist Watch
How to use a chronograph watch factions
Thank you for contacting FixYa.
  • Identify the push button that controls the second hand. With the watch face positioned so that 12 is at the top, locate the button on the right of the watch's rim and above the watch stem.
  • 2
    Grasp the watch stem tightly and tug it out, away from the watch rim. Pull it past the first area of resistance, a position used for other settings, to the second stage of resistance where it will not pull out any further.
  • 3
    Press the second hand push button, identified earlier, until it is firmly depressed into the watch rim. Release the button, allowing it to return to its normal position.
  • 4
    Push the watch stem back to its original position tight to the rim.
  • Jewel
    Sep 14, 2010 | Fossil BQ9165 Wrist Watch
    Can I power off my Casio efa-119bk watch when not wearing it so as to reduce battery consumption. Thanks & Regards
    You can pull out the stem when not wearing to save on the battery. Most jewelery stores use this practice as well.
    Best regards.
    Jewel
    Aug 31, 2010 | Casio EFA119BK1AV Watch
    How do I reset thebattery on a casio ad-520?
    To reset the battery you need to locate the "AC" inside your watch. The AC terminal is a little metal spot (usually a circle and usually gold colored) on the inside of your watch. Looking at the inside of your watch the "AC" should be labeled, though it may take a magnifier to identify it.
    It may be labeled simply "AC" or it may have an arrow pointing to it. Once you locate it use a pair of tweezer or a paper clip and touch the battery and the AC together for a few seconds and release; you may have to do this twice. This will reset your watch an give you the ability to correctly wet your watch.
    Oct 21, 2009 | Casio Marine Gear AMW320D9EV Wrist Watch
    Removing the crown/stem of CASIO EF-321
    Other case for a simple Casio quartz watch :
    Jan 15, 2009 | Casio Edifice EF106D2AV Wrist Watch
    How do i remove crown?
    Hi, on the back of the movement there should either be a screw or a dimple in line or next to the line of the stem. If a dimple, press in with a pin or similar sturdy tool and gently withdraw the stem. If a screw, only one turn should be enough to release the stem
    Nov 13, 2007 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
    Watches Logo
    Top Casio Watches Experts
    Janelle Schoonover
    Janelle Schoonover
    Ekse
    k24674
    Are you a Casio Watch Expert? Answer questions, earn points and help others
