Lambert Philip Posted on Oct 14, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No volume from the speakers - The Audio Players & Recorders
Franco Dosil
Level 3:
Top Expert:
  • The Master 10,542 Answers
  • Posted on Oct 14, 2019
Franco Dosil
The Master
Level 3:
Top Expert:
Answers
10542
Questions
0
Helped
377285
Points
178965
Hello Lambert Philip, indicate brand, model and type of equipment you are commenting on, in order to find the best possible solution
I wait your answer
Regards Franco Dosil
Hola Lambert Philip, indica marca, modelo y tipo de equipo del que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
How do I increase the volume on the speaker?
Search Results
    How to improve sound quality and increase volume on ...
    https://www.androidpit.com/improve-the-sound-and-volume-quality-on-...
    Dec 4, 2015 - Not all smartphones are blessed with speaker quality or volume levels to make your stereo envious. ... How do you improve sound quality on your phone? ....I've seen a 'little' cellphone case, foam padded with a zipper, that ...
    How to increse speaker volume on android smartphone
    www.instructables.com/.../How-to-increse-speaker-volume-o...
    InstructablesRequirements:You will need a phone with Mediatek chipset. ... is a quick turtorial on how to increase the volume of front-facing speakers on android smartphone.
    Increase your Android Phone's Audio Output with Speaker ...
    www.techverse.net/increase-android-phone-volume-output-speaker-boost/
Jan 27, 2016 • Cell Phones
1helpful
I just connected my Logitech lS11 speakers. How do I tell my computer that I now have these? When I click on my volume icon in the tool bar to adjust my volume does not work? thank you
Windows does not detect specific models of speakers. I would adjust your Windows volume all the way up and then adjust the sound on your volume knob on speakers. This way the sound volume is easier to adjust on speaker than using the volume control in the toolbar.
1helpful
I have the volume to my speakers at full volume and I can't hear the sound very well. Any suggeations?
Could this be because the speakers are under your laptop? Propping it up might help. Or alternatively check the volume control. There is seperate volume for main volume and wav volume. Raise them both. -Ravi Shanghavi
2answers
I have a pair of JBL Duet speakers and 1 doesn't work unless the volume is maxed out on the other.
mcdevito75 here, Try to increase the volume from your keyboard, Then adjust the volume at the speakers, there should be only 1 volume control on 1 speaker to control them both, also check your connections at both speakers.
2answers
Problem with volume controlwhen i shake it the speakers crackle but no volume
It's just "dirt" on the mechanical part of the volume-control. Either you take the speakers apart, and use denatured alcohol and Q-Tips(tm) to clean that part, or you replace the volume-control, or you replace the speakers.
1helpful
2answers
There is a loud hum when volume is on low to high
go to control panel
sound and audio devices
voice
under voice recording clk volume and mute the mic phone...........
or
some how your mic is conflicting with speakers. Keep your mic away from your speakers..
Do reply if this woks
7helpful
3answers
The volume of the callers voice is so low that it is almost inaudible
u increase the volume.....for example make a sample call...while calling now press the forward direction button in ur mobile....volume ll increase...
hope this is helpful!!!!!
Sep 29, 2009 • Cell Phones
2helpful
Low volume on creature speakers
Your speaker volume must have reset. You have to touch the dots on the right speaker to turn up the volume to desired volume. I just remembered that on my system. Hope this helps.
Volume control unresponsive
The LED didn't turn on ,indicate the DC pwr was missing , you need to ensure there is a Dc supply to the speaker unit,once you got the LED on you will be able to control the volum.
Top The Audio Players & Recorders Experts
vince
Paul Carew
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
