Refrigerators Logo
S
Steve Tidler Posted on Oct 14, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Margaritaville (Sunbeam) blender won' t run
Forgot to empty ice bin on Fiji (model DM 2000) from previous day and water overflowed reservoir. Outlet checks good as well as kill-switch.
Ernest
Level 3:
Master:
  • Master 489 Answers
  • Posted on Oct 14, 2019
Ernest
Master
Level 3:
Master:
Answers
489
Questions
Helped
183865
Points
2971
MargaritavilleCargo.com Customer Service
1-877-689-2737
3 Related Answers
marionbagget
  • 718 Answers
  • Posted on Mar 24, 2009
SOURCE: Ice maker for Kenmore model 532343 not working
Does your water have minerals?
Faulty Water Valve
Your ice maker is designed to fill with water for 6 to 8 seconds. Check to see that the ice maker is not sending power to the water inlet valve for a period longer than what you unit is designed for. Does your water have minerals?
Also check to see if the water inlet valve is closing too slowly. The power to the valve is being shut off in the correct amount of time, but due to wear and tear in the valve, it is closing too slow.
Check the timing on the value. Put a volt meter across the leads of the water inlet valve. Set the voltage range to cover the 120v voltage. Cycle the ice maker and watch the meter. When the ice maker begins to fill with water the meter will read voltage coming from the ice maker. Time the difference between when the voltage is cut from the valve and when the water quits filling the ice maker.
If the water shuts off immediately when the voltage is removed, the valve is probably good. Since it was off 10 days the particle build-up on the valve may be the problem since it could solidify. You could try working the valve back and forth or replace it.
If the valve closed quickly then the problem is the valve was opened too long.
If that is the case then you have an ice maker control problem. In that case see if the timing can be adjusted.
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
  • Posted on Mar 31, 2009
SOURCE: Margaritaville professional blender DM 1000 - 33 parts
Here is the official accessories order form page - your exact item isn't on the current list, so you may have to cell them directly - 1-877-689-2737:
http://www.margaritavillecargo.com/Accessories.aspx
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: Replace the glass pitcher for the Margaritaville blender
Replacement pitchers here:
-Tha Mp3 Doctor
Margaritaville DM2000 blender. I need a blender blade replacement for it please?
Question edited for clarity. Easily available.
Margaritaville Blending Blade Replacement Part Only ...
https://www.ebay.com > itm
Item specifics ; Brand: Margaritaville ; Type: Blending Blade ; Appliance Capabilities: Blend ; Color: Silver ; Model: DM2000.
US$17.95
Margaritaville DM2000 Parts ' Small Appliances
https://www.appliancefactoryparts.com > smallappliances
Buy Genuine Small Appliance Parts for Margaritaville DM2000. ... Replacement parts arrived on a timely basis, fit perfectly and were easy to install.
margarita machine replacement part blender blade dm2000
https://margaritaville.blendersi.com > margarita-machin...
Margaritaville Margarita Machine Replacement Part Blender Blade · USD $13.99 · Recommendation: USD $13.99 · USD $13.99 + no tax + Free 3-6 days Shipping.
US$13.99
Cant take apart ice crusher portion of unit
The Ice Reservoir has a release botton at the back of the reservoir. The button must be pushed down at which time you can lift from the back and remove the ice reservoir. You can download the operating instructions for your machine here:
http://www.jardenstore.com/manuals/MANUALS/DM1000-000-000_43_64821634.PDF
I need the plastic piece that goes on the back of the Margaritaville DM0500. I think it holds the run off from the front of the machine???? I don't really know it's purpose. It's shaped to...
The part you are looking for is called the Ice Melt Reservoir. It collects the water from the melting ice left in the Ice Reservoir.
The manufacturer has a Parts & Accessories page here:
http://www.margaritavillecargo.com/accessories.aspx?pid=1375
Parts & Accessories for your blender are also available here:
http://www.blenderexpert.com/margaritaville-blender-parts.html
Unfortunately the Ice Melt Reservoir does not look to be a stocked part. I would recommend you contact the manufacturer directly to inquire whether this part can be made available. See their webform here:
https://secure.margaritavillecargo.com/ContactUs.aspx
For future reference your Manual can be found here:
http://www.margaritavillecargo.com/manuals/MANUALS/DM0500-000-000_43_27862119.PDF
Where can I find parts for Model DM 1250?
Try this link: http://tubeguy.org/household/margaritaville_parts.html
Where can i find a replacement ice reservoir lid for a margaritaville machine
Did you ever find a replacement ice reservoir lid for your machine?I need one also but can't find it anywhere!
2helpful
3helpful
Margaritaville Frozen Concoction - Ice shaver has stopped turning
On my machine (DM1000) there is a kill switch on the top & back of the ice reservoir. If that gets broken/misaligned the shaver will not activate.
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
