You have to start the sequence with a slightly different formula because there is no preceding value for Monday.
The rest of the formulas are running totals so they are the same just dynamically duplicated down the column add infinitum.
Just duplicate the the formula Picking up the value form the result column and subtracting the next running subtraction value.
SUM means adding not subtracting. so if you were wanting to add the total (the sum) of the amounts of the hundreds and the tens would be 170 plus 130 which would be 300 but the remainder from subtracting 130 from 170 would be 40. That would leave the single units 5 minus 4 of which the remainder is 1. So, the remainder from subtracting 134 from 175 is the reminder of subtracting the one hundred from the one hundred which is zero added to the remainder of subtracting the tens (70 minus 30) which is the remainder of 40 plus the remainder of subtracting the units of 5 minus 4 which is 1. So you need to add the 0 and the 40 and 1 which is the remaining sum of 41.
Remember that the SHARP calculator does not solve algebra.
But some tips for adding and subtracting monomials include:
Group all the terms that are like terms (they have the same variables and exponents. Make sure that you move them with the sign in front of them (dont lose your minuses).
Add or subtract just the numbers in front of the terms and leave the variables exactly as they are when you write down the answer.
Seconds: Subtract 12 from 35 to get 23.
Minutes: Subtract 23 from 45 to get 22 Hours: Subtract 0 from 2 to get 2.
Put the three together to get 2.22.23
This one was easy because there was no need for carry. If you do have to carry, just make sure you carry 60. Otherwise, it's exactly the same as when you learned subtraction in second grade.
Some calculators have conversions between decimal degrees/hours and degrees/hours:minutes:seconds. If you have such a calculator, you can convert both numbers to decimal, subtract, and convert back. Since you didn't specify what calculator you have, I can't tell whether this is an option for you.
Hi, to "Subtract a >Higher (#,$) numbers from a <Lower (#, $) numbers; you take the "bigger number 167, place that number (over the smaller number 78 and from (right to left) take away numbers. Example: 167 - 86 = Think of 167 as $167.00 and 86 as $86.00, so to make $86.00 into $167.00 you'll need a $81.00 more. So if you think about how much more money you will need to "Add" to make a certain amount, it is just the same as how much you "Don't have! You have $167.00 when you go shopping for clothes, and you spend $86.00 when you count how must money you have left, it add up to $81.00 "That's "Subtracting." "Subtract (167 from 86 you get 81). " Always remember the Higher, or Larger number goes on top! " If you want to check to see if the answer is "right," add the two number together,(86 + 81 = 167). "I hope this helped you, rating the solution is appreciated, thanks"
When you want to complete a problem on an adding machine, such as "7 - 3," you would not key in "7," then the subtraction sign, then "3" and then an equal sign. If you do, then you will get an answer of "-4," and you know that is not the correct answer. Again, you have to think like an accountant when you are working with your adding machine. To figure this subtraction problem on an adding machine, you would need to key in "7," the addition sign, "3" and then the subtraction sign; you would get the answer of 4. You are actually working the problem as "7 + (-3)." This would be true on most modern day machines. In order to subtract, you have to add the negative number.
Sorry, I don't clearly understand what you want to do, but if you can explain a little more, I can help. If you want to subtract one cell from a column total, sum the column and subtract the one cell. If there is a need to subtract adjacent column entries, or similar type needs, there are formulas that can do this easily as well. Just a little more info - we'll have a FixYa!
