My West Bend 33600 leaks. I just bought it used on Ebay for my church. When we tried to use it the water immediately leaked out through the glass tube (coffee level indicator). Does anyone know if there is a washer at the bottom of the coffee level indicator? There seems to be a lot of play between the glass and the metal. Shipping is expensive from Hawaii and I don't want to send it back as I will eat about $40.00. Can anyone help me with some suggestions??
Thank you!
SOURCE: New spout
hello!
try this!
http://www.abtecparts.com/westbend.htm
Try this to order all of your part needs
eric
SOURCE: West Bend 33600 heats to 178 degrees
Im sure one of the thermostats is a high heat thermostat but more than likely the element is covered with lime, I would put some diluted "Lime Away" and let it soak for a few hours then drain it and run clear water through it three of four times.
If this doesn't work for you then I would change the high heat thermostat.
SOURCE: West Bend 100-cup commercial urn -33600. Need
You can download the manual for your West Bend coffee maker from this page:
http://www.focuselectrics.com/catalog.cfm?dest=itempg&itemid=30&secid=54&linkon=category&linkid=62
SOURCE: I need Part #P139-97 High
THE PART NUMBER HAS BEEN CHANGED IT IS P200-97
YOU CAN GET IT AT
HERITAGE
THE PHONE NUMBER IS 1-800-458-5593
Water Level Measure of Ground Coffee
100 cups 6 ¼ cups
80 cups 5 cups
60 cups 4 cups
40 cups 2½ cups
Do not make less than 40 or more than 100 cups of coffee at one time. Use electric perk or regular grind coffee; a filter liner is not necessary.
