Cell Phones Logo
A
Anonymous Posted on Oct 13, 2019
My phone techno pouvour 2 IMS has stopped working can not go to Roaming
The Spaminator
Level 3:
  • Cell Phones Master 628 Answers
  • Posted on Oct 14, 2019
The Spaminator
Cell Phones Master
Level 3:
Answers
628
Questions
0
Helped
142467
Points
41137
Contact your cellular network provider and tell them you phone will not roam
2answers
I want to use my apple phone in Ethiopia
your phone needs to be factory unlocked. You can contact Web Design Miami Computer Repair Miami Iphone Repair Miami Data... and they can help you out
How to turn off roaming?
If you need to stop Roaming phone signal while visiting abroad,You should keep in mind the following instructions
1.Turn your voicemail off
2.Just switch Data Roaming off with a help of your service provider.
3.Try to access network through Wi-Fi while visiting abroad.
4.You can also avoid roaming by use the local carrier sim card,which is available in that country.Before put local carrier,Make sure your phone is unlocked or not.If it's restricted by some network,try to unlock your phone using
SuperUnlockCodes.com
Samsung europe
Yes,It will work.But Roaming charges will be applicable.
Unlocking4U.com
Turn off roaming
Unlocking4U.com
Apr 11, 2014 • Cell Phones
Stop roaming
If you need to stop Roaming phone signal,You should keep in mind the following instructions
WickedUnlock.com
2answers
My phone is saying digital roam mode when i make an outgoing call, how do i take it off so i can make outgoing call with no problem.
This is pretty much what you need to do. Just turn off all the roaming features. However when you roam it typically means you dont have service through Sprint so dont be surprised if when you turn off roaming capabilities your phone doesn't get ANY signal. Here's the link to your phones manual page 112 is about roaming.
Setting Roam Mode
Your phone allows you to control your roaming
capabilities. By using the Roaming menu option, you
can determine which signals your phone accepts.
Choose from two different settings on your phone to
control your roaming experience.
1. Press > Settings > More... > Roaming > Set Mode.
2. Highlight an option and press .
n Sprint Only to access only the Sprint network and
prevent roaming on other networks.
n Automatic to seek service on the Nationwide Sprint
Network. When Sprint service is unavailable, the
phone searches for an alternate service.
Call Guard
Your phone has two ways of alerting you when you are
roaming off the Nationwide Sprint Network: the
onscreen roaming icon and Call Guard. Call Guard
makes it easy to manage your roaming by requiring an
extra step before you can place or answer a roaming
call. (This additional step is not required when you make
or receive calls while on the Nationwide Sprint Network.)
To turn Call Guard on or off:
Call Guard.
2. Select On or Off.
To place roaming calls with Call Guard on:
1. From standby mode, dial 1 + area code + the
seven-digit number and press .
2. Read the message and press .
Note Call Guard is turned on by default on yourphone.
To answer incoming roaming calls with Call Guard on:
1. Press .
Data Roam Guard
Depending on service availability and roaming
agreements, yourphone may be able to access data
services while roaming on certain other networks. You
can set your phone to alert you when you are roaming
off the Nationwide Sprint Network and try to use data
services such as messaging.
To set your Data Roam Guard notification:
Data Roaming.
n Always Ask (default mode) sets your phone's Data
Roam Guard feature on. You will see a prompt that
will require you to respond anytime you access
data services while roaming.
n NeverAsk turns your phone's Data Roam Guard
feature off. Your phone will not notify you of your
roaming status when you access data services.
Touse data services when Data Roam Guard is active:
© When a notification appears informing you that data
roam charges may apply, press ROAM (left softkey)
to connect.
Note If the Call Guard feature is set to On, you need to
take extra steps to make and receive roaming calls.
My blackberry bold stopped working on roaming network
1.INSERT THE SIMCARD IN OTHER MOBILE AND TRY ....
2.IF SAME PROBLEM PERSIST CHECK WITH THE SERVICE PROVIDER OR CARRIER AND REQUEST FOR ROAMING SERVICE TO REPROVISIONED....
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
