To remove the code, press pause or cancel button twice and the power button once. If the code is still displayed, unplug the washer or disconnect the power for one minute. Items were detected in the washer during the Clean Washer cycle. Remove items from the drum and restart the Clean Washer cycle.Jun 13, 2019
Error Codes in Front Load Washers - Whirlpool Home Appliances
https://producthelp.whirlpool.com > Washers > Washer_Product_AssistanceSearch for: How do I clear the error code on my Whirlpool washer?
SOURCE: Whirlpool AWM 8023 -error F06
This erroe code means drive motor tackometer error Probably a bad motor or motor drive pc board or cable problems
SOURCE: whirlpool washer duet
F/06
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
SOURCE: F06 error code on Whirlpool duet washer
I have the whirlpool Duet 9150 with the same issue. I removed, reseated and reconnected every connector at least 4 times with the same random result of F06 to the point where it no longer finished the load. I then removed the motor control board again and sprayed it down with electronic cleaner along with all connections by disconnecting them , spraying them down and then reconnect and connected a few times to ensure good contact. I then tried again and the F -06 code came back. I then ordered the board for $ 150 online . When the new board arrived 4 days later, my wife tried the washer one more time and it worked. I have performed over 2 dozen loads . The board was never replaced. It appeared that spraying the board and connectors worked.
SOURCE: f06 error code on Whirlpool duet washer
SOURCE: F06 error
HI There
Here what you need on error codes.
Drive
The
Hope this helps let me know. Thank you for writing to fix ya.
Best regards Richard
