SOURCE: Samsung DLP HL-R-5667W lamp LED comes on solid, no picture, then turns off
DO you have the owners mannel if so read it and see what they would do ,have you removed the lamp and if so how did it look? some lamps only last for 5,000 hrs and others 8,000 hrs If lamp is bad TV will not come on.
SOURCE: Removing Door Trim
hi-- the inner door handle is tricky! it is held in by clips that SLIDE BACKWARDS!! apply a little inward pressure then slide the handle assembly back!!-- then you will have to remove the metal rod from the handle----------putting it back is the reverse.----cheers
SOURCE: I want to replace the
You need to remove oven top cover--6 screws. You may need to bend 2 flaps out of the way next to power conduit.
