I have JBL Linkview speaker and its stuck in demo mode.
SOURCE: Stuck in demo mode
When you are in STANDBY mode hold the menu button for a few seconds and a special menu should pop up. In this menu you should be able to set the clock, turn off or on the beep, and take your unit out of demo mode. Good luck.
-Andrew Hawkins
SOURCE: Sony HCDX1 STUCK IN DEMO MODE
I don't have a Sony HCDX1, so if this doesn't work, please do not rate me down.
Push the PLAY and STOP buttons (at the same time) and hold them for about ten seconds. This should get you out of DEMO mode.
Power the unit off, then back on. If the display now says LOCKED, then press the PLAY and STOP buttons (at the same time) again to unlock.
If this does work, please rate it Solved, so others can use this solution. Thanks!
SOURCE: Aiwa CDC-X504Mp stuck in demo mode
This recently happened to my Sony, maybe it will help u
If this cd player has a removal fascia then try..
Carefully inspect the the electrical contacts on the fasica and the cd player. If it has got dirt on them then CAREFULLY CAREFULLY clean with cotton swab dabbed in cleaning Alcohol.
to deactive demo mode press menu on the remote...then w/that screen up push the screen mode little gray button at the top of the remote...note that this will not change anything on the screen...i know weird huh...now type in the numbers 9012 you should now be at a new menu the top opption is demo mode...choose it and then choose on or off...good luck i see this i an old post but i hope it helps someone...
