if u want to change start name on taskbar then u've to go on this link and get the RESOURCE HACKER s/w.
http://forum.codecall.net/tutorials/4111-how-change-start-taskbar.html
Here is the solution:
Go to Control panel
Double click on User Accounts
Click on Manage User accounts
Double click the name of the account you would like to change
Change the name as per the prompts
Voila!
If you are looking to change the name on the XP start button please go to the following link and use the instructions at your own risk:
http://www.theeldergeek.com/change_text_on_xp_start_button.htm
Happy name changing
1. Click the "Start" menu.
2. Select "Control Panel".
3. When the Control Panel appears, select "User Accounts".
4. When the "User Accounts" window appears, underneath "Or pick an account to change", click your account name.
5. Click "Change my name".
6. Enter in a new account name and click "Change Name".
Hope this helps - good luck!!
It is possible to change the Start work to your name in taskbar with the help of Resource Hacker tool available on internet. Lots of tutorial available on google to do this.
We recommend you not to do this. It breaks the windows file protection which can lead to some strange problem in windows.
SOURCE: i wanna to change of the windows xp's strat name
Download a software named resource hacker from internet. Its of some kbs only. In that software you open your "explorer.exe" located at C:/windows/ In that go to String Table->37->1033->and change 'start' to 'yourname' Do not remove single quotes. Save it with other name as "newexplorer.exe" But before doing this make copy of your explorer.exe in other drive or place. Now change the registery by writting "regedit" in Start->Run Navigate to: HKEY_LOCAL_MACHINE\ SOFTWARE\ Microsoft\ Windows NT\ CurrentVersion\ Winlogon In the right pane double click the Shell entry to open the Edit String dialog box as shown. In Value data: line, enter the name that was used to save the modified explorer.exe file. Click OK Close Registry Editor and either log off the system and log back in, or reboot the entire system if that?s your preference. If all went as planned you should see your new Start button with the revised text.
SOURCE: i want to change start button s name on taskbar
Visit
http://www.theeldergeek.com/change_text_on_xp_start_button1.htm
and the site will guide you on how to change the windows xp start button text.
Also there are several guides available on YOUTUBE that will help you.
Hope it helps.
Regards,
Grydor.
SOURCE: how to change start name on taskbar in win xp
Hello shinde_jagan,
I've posted a link to an article below that explains step by step how to change the text in the start button.
Change Start Button Text
Hope this helps, don't forget to vote. Thanks :)
