Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Agitator starts at begining of cycle before washer is full
Hello good people, please help: The agitator of my stack washer starts turning at the start of any wash cycle while the tub is being filled, does this on fill-up for rinse too.
Known: (1) water fills the tub to the desired level, no problem stopping or starting that; (2) lid switch (open) stops the spin cycle, close starts again. However, I can open lid during the wash cycle and it does not stop the agitator movement - is this right?
So essentially I have to fill using an in-between place on the "delicates cycle", once full, then turn knob to a "wash cycle" before it starts on it's own with the lid up. Once it finishes washing, drains, starts to fill for rinse, the agitator starts to move again while the water is filling up...but there's not enough water yet... water does stop on it's own, but the agitator is moving all the time.
  • celrus Nov 12, 2009
    Answer: I bought a new $100 timer unit, problem was the same. As I started checking out other connections I noticed that inside the front panel of the washer, way up in the top back edge, some wires appeared mashed. Sure enough on closer inspection, the wires to the lid switch had been slammed against the washer side, right on a metal lip, by the basket during some off-balance cycle.
    I simply fixed this and covered with e-tape, then duct taped the whole mess to the inside wall away from the metal lip so it wouldn't happen again. Everything works fine now.
    Moral of the story: take time to check all connections and follow wires with a flashlight to ensure nothing has been injured... especially if you remember a big-time off balance event prior to problems.
  • 38 Answers
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Posted on Sep 26, 2009
SOURCE:
Drum knock when spin cycle
Hello.
Noises are common when using a two-in-one washer and dryer, as clicking or whirring is part of the cleaning process during the transition to the next cleaning process. The GE Spacesaver washer and dryer combo uses a top-loading washer stacked beneath the front-loading dryer, and uses an agitator that makes noises throughout the spin cycle. Although whirring or clicking is normal, other noises or malfunction indicates a problem with the washer that requires minor troubleshooting. Professional repair is necessary if the washer continues to experience problems during the spin cycle, as there may be a problem with the washer's agitator.
1 Open the washer's door and check the balance of the load's clothes. Clothes that are unevenly distributed around the agitator cause excessive shaking and result in an imbalance during the spin cycle. Reduce the load's size by removing clothing if the washer's drum is overloaded.
2 Push "Start/Pause" to pause the spin cycle and turn the washer's cycle knob to the "Off" position. Turn the knob to "Spin Only" and press "Start/Pause" to reset the cycle.
3 Turn the wrench counterclockwise or clockwise around the unit's legs to adjust the appliance's balance. The legs are adjustable with the help of a wrench to ensure the unit does not shake while in use. An unleveled unit shakes as it spins, and causes excessive squealing or rattling as it attempts to dry the clothes.
4 Touch "Start/Pause" on the front of the washer's control panel and unplug the washer/dryer unit's power cord from the electric oultlet. Wait two minutes and plug the power cord back into the electric outlet. Push "Start/Pause" to resume the spin cycle.
Thanks.
Nov 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Why wont my washer agitate
must be worn out dogs
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 22, 2010 | Kenmore 98702 Stacked Washer/Dryer
Washer keeps spinning. doesn't move to next cycle
It sounds like the agitator , air bell or transmission is failing. Since the unit spins the belt & motor is ok. I recommend removing & inspecting the agitator & air bell. If they are not stripped out then you have a transmission failure.
Or, start the washer at the beginning of a cycle set to the lowest water level. After the unit fills it should be agitating stop the washer. Open the lid & try moving the agitator, if the agitator will not move it is good & no need to remove for inspection. You have a bad transmission. If the agitator moves easily then we know that the agitator or air bell is stripped out & will need to be inspected for confirmation before replacing.
Hope this helps.
Thanks for using Fixya.
Dec 09, 2009 | GE Spacemaker Washer and Dryer Electric...
Agitator doesnt start
Sounds like the lid switch is acting up on you.
Jul 26, 2009 | Whirlpool LTE6234D Top Load Stacked...
Frigidaire washer spins but won't agitate
when you try to spin the Agitator dose it spin freely both ways if so the DOG EARs are stripped and need replacing Take cap off top off agitator to access the bolt holding the n in place and the Agitator off
Oct 22, 2017 | Frigidaire Washing Machines
Water fills to proper level but agitator doesn't come on instead there is a grinding noise, when I move control to just prior to rinse cycle water drains properly, but still just grinding or buzzing n
Hi, Do you know if the washer spins at all?
It sounds like the coupler has gone bad.
Please let me know if it spins at all.
I can send yyou instructions on changing the coupler.
Vic
May 28, 2009 | Whirlpool LTE6234D Top Load Stacked...
How to remove the agitator??
remove agitator cap ,,looking down in agitator removre the plastic seal with a firm yank,,now you can see the agitator hold down nut,,remove that bolt with 1/2 inch nut driver or wrekit,,pull agitator..if clothes is jammin it down take you belt and slide under agitator,,and pull booth ends ,,but away from your fast ,may come up fast..always unplug
Oct 28, 2008 | Whirlpool LTE5243D Top Load Stacked...
Kenmore electronic 90 series washer
easy easy you need agitator dogs thats right the official name of the part is agitator dogs! 5 dollar part can chat you through the fix
Mar 25, 2008 | Kenmore 22422 Top Load Washer
Agitator always moving
The inner tub on some machines does rotate very slowly while filling to assist with the even distibution of the load. If the agitator is turning back & forth while in fill mode, you could have a timer or transmission problem. You need a tech.
Nov 04, 2007 | Kenmore 98702 Stacked Washer/Dryer
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
719 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
