Sir I have a Konica Minolta magicolor 2530 DL printer It show the massage End of Drum Cartridge. I change the Drum with new. But it also show the same massage.
Sir I have a Konica Minolta magicolor 2530 DL printer It show the massage End of Drum Cartridge. I change the Drum with new. But it also show the same massage. Sir I have a Konica Minolta magicolor 2530 DL printer It show the massage End of Drum Cartridge. I change the Drum with new. But it also show the same massage.
You can't post conmments that contain an email address.
I had this same problem however I was using the Magecolor 7450. I was trying to print a C5 postcard and the right hand side of the document was getting cutoff (aprox 2 in). Changing my Paper-Type settings on the printer from "Postcard" to "Any" magically fixed the problem.
A drum cartridge is the rotating drum that puts the toner onto your copy's! You would need this to make copy's and after its empty, it would need replacing.
If this was helpful please rate with a 4 thumbs up!! Thanks for using fixya.com!!
The drum and the black printer cartridge are two separate items. You will have to purchase a new drum for it. I just had to do the same thing and it ran me $150.00 at Staples.
Open the Front Cover and remove the OPC drum cartridge by pulling up from the green lever. I'm sure you'll find all these instructions on the box the new drum is comming.
pleas check transfer belt, and drum unit, probably these lines are
caused by drum unit and you have to change it. also you can clean laser
glass, what is under the drum unit. if both look fine you can also look at the fusing rollers.
