SOURCE: body sculpture BT2710 instructions
hi if you email body sculpture on [email protected] they will send you a free manual by pdf they are brilliant i know because i have used them for the same reason myself last week
Jules
SOURCE: I have no instructions for an MB sculpture puzzle
Hi DEEHARDY,
I bought tge same puzzle (I think) from a fleemarket yesterday!
It was very old and had been there for a long time I think, but the box was unopened!! In it all instructions were in all other languages but not in english. But I know some German so I managed to understand! The thing with the puzzle is to try yourself first how You think it is supposed to be. But in the intstructions there is given a hint with "mirror text" if You can not get started. Here I give You the hint: If it is the same puzzle, You can see a four digit code on each piece. The second number tells You in what part of the puzzle the piece should be. Example: All pieces with second number a three should be in the same "part" or area. Then You should take the two last numbers from the code and minus the first number, example 13-6=7 then this piece is the seventh piece in the third module. You will get for all modules pieces with numbers from 1 to 30 after some calculation. Put the pieces in order smallest most under and bigger higher up. And start with "module" 1.
This was at least how my puzzle should be assemblied. I hope this helped You!!!
Greetings from Finland!
SOURCE: bought a used big ben 3d puzzle does not have
here you can download the instructions: http://depositfiles.com/files/eax91xj64
SOURCE: I need the instructions for
I have attached a link to the instructions.
http://www.hasbro.com/common/instruct/3DSculptures-KingTut.pdf
Enjoy,
Icom1
SOURCE: I have no instruction manual
Here is a link to the manual. Enjoy!
http://www.hasbro.com/common/instruct/3dSculptures-TheEternalWoman.pdf
