Boating Logo
Posted on Sep 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
40 Hp Johnson outboard motors stalls out after a few minutes running then takes forever to start again
Dean
Level 2:
  • Expert 285 Answers
  • Posted on Sep 17, 2009
Dean
Expert
Level 2:
Answers
285
Questions
0
Helped
186072
Points
831
May likely be one of two problems:
1. Fuel flow: Make sure fuel tank vent is open and not blocked while engine running. Check primer bulb is working and no air leaks along hose anywhere. Check function of fuel pump and ensure fuel is getting to the cylinders.
2. Overheating: Check engine isn't overheating and that water pump is operating properly while engine is running.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 01, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1323
Points
How do u change a fuel pump on a 40 hp johnson boat motor
1helpful
2answers
1957 johnson outboard 10 hp fuel mixture ratio
https://www.google.com/search?q=1957+johnson+outboard+10+hp+fuel+oil+ratio
What is the mix ratio for a Johnson outboard motor?
Any Johnson outboard motor built since 1964 requires a 50/1 fuel ratio. Motors built prior to that date require a 32/1 ratio, with the exception of a few fishing motors built prior to 1955 that use a 16/1 ratio.
Feb. 22, 2021
What is the mixing ratio for a Johnson outboard motor? - Mvorganizing.org
115 johnson moor spits and sputters when idle and stalls when shifted into gear
Has this engine been sitting for a while?? Sounds like the carbs need cleaning and setting... a job for a professional!! A professional motorcycle mechanic can do this also!!
1helpful
Johnson outboard stalls when it warms up
Little Johnson outboards are famous for being very easy to start, So- first pump up the gas, then set the throttle open to the neutral stop -pull thru once -then set the choke to fully closed (look down the carb and see if it is) and pull thru 2 more times- open the choke. try again --If it is not running by now you have a bad ignition, or the engine has no compression. - very likely if you are running the wrong spark plugs. You may have some shattered reed valves.
See if the spark plugs are getting wet with fuel.
Sep 08, 2012 • Boating
3answers
How do i replace the water pump in a 2005 150 hp evinrude outboard motor
Take the cowling off. Also drop the foot. There wil be a stainless linkage rod that runs the length of the motor that you will have undo to drop the foot. The water impeller will be inside a stainless casing that you will have to disassemble.
Aug 17, 2012 • Boating
1helpful
6hp Johnson outboard stalls & quits
go to an auto parts store and get a can of gasoline additive called seafoam. Read the label so you know how much to add to your 6 gallon tank. This stuff works wonders on outboard motors.
Sep 16, 2009 • Boating
1974 johnson outboard motor 25hp stalls when hiting high end
Not familiar with that specific motor but had similar vintage smaller HP Johnsons. From my experience it sounds like it could be that the high speed carb adjustment is too lean. What I would try is running the backing off the high speed screw 1/4 turn to 3/4 turn, then test. If works better, screw back in in 1/8 turn increments until the problem recurs, then back out 1/4 turn and leave it there.
1helpful
Boat engine 1995 Johnson Outboard 70 HP
Ihave a 1991 70 hp Johnson outboard thats hard to start the first time but starts good after that. Seems to be flooded. Starting rpm seems to be low.
Jun 25, 2009 • Boating
Johnson Outboard motor. 3.3 HP.
Hey BK, Its still the carburetor!.... take it to a qualified professional.. there are TOO many tiny passages and jets that must be perfectly clean for a small engine to run properly..
Top Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you a Boating Expert? Answer questions, earn points and help others
