SOURCE: GE dehumidifier light says bucket is full but it isn't
Try feeling both sides of the outside of the bucket and make sure the bucket is flush with the dehumidifier. If one side is sticking out more than the other it may notbe engaged correctly which will cause a full bucket notification. If everything checks out ok there try takng the bucket out and push in on the button that the lever from the bucket engages on at the dehumidifier. If the light turns off after you push on the red button that means the bucket is not engaging correctly. If the red light stays on and it doesnt make a difference he button sensor may be defective. If you found this solution helpful please rate it.
Thanks - Tech101
SOURCE: Dehumidifier Error?
This error code indicates that the problem is most likely a shorted defrost thermistor or possibly a pinched wire going to the thermistor. You will need to replace the sensor assembly - part # 6877A30013L. The Sears website has it listed for 9.99 + shipping. The humidity sensor & defrost thermistor come together in a wiring harness that plugs onto the main circuit board. It is fairly simple to repair. Just remove the front & rear grill & the metal cabinet. Remove the thermistor from the copper tube on the cooling lines; remove the humidity sensor from the front of the evaporator; pull the wire plug off the bucket switch; & remove the small 7 pin plug from the main circuit board inside the metal control box. Reverse procedure to install new sensor assembly.
Same problem with Goldstar model DH404EY7 -- stop code 01 on startup, bucket full light blinks (drains to floor).
Replaced the main controller board to fix it.
For my model dehumidifer the part # is 6871A20888A, and cost $77.44 (not counting shipping) from Appliance Factory Parts. The Appliance Factory Parts web site also provides parts breakdown (exploded parts diagram) diagrams and service manuals in PDF form.
SOURCE: 'bucket full' light on, but bucket empty
There is likely a switch operated by a float to turn that light on and turn off the compressor, sometimes manufactures use a rubber "O" ring on the float shaft and they can slip. take the cover off the pump and check the float or in some cases one of two floats are used. Once float turns the pump on and off and the second float shuts OFF the compressor and turns ON the full reservior light.
SOURCE: My new LG "ld450eal" DeHumidifier
The switch that says 'Bucket is full' is not adjusted properly.
It will need to be adjusted, normally a screw driver or pliers,
so that when its empty the switch is not made or the contacts
are open.
If it is in adjustment properly, then the switch is bad and needs
replacing.
Before you replace it, check to make sure the wires leading to it
are not touching, it may be sending a signal meaning 'full' by
electricaly touching each other at the switch.
Hey friend, thanks for your post!
It sounds like your dehumidifier needs to be professionally cleaned. What could be causing the problem is a buildup on the inside of your dehumidifier where the water drains out and it is causing the water to not drain properly. Additionally, I would check to verify that the drain hole is tightly secured with the plug. I know you stated that the bucket is not leaking but have you removed it to verify? Please comment back if further assist is needed. -Matt
