Bob weight &pivot pin fell off...how do you gain access through freezer door???????thanks tommyrod
Access from front of freezer door. Trim is just pushed into friction holders. Selector area snaps in. Phillip screws under that removes ice shoot.
Testimonial: "very helpful thank you..worth the fee"
Remove the top freezer door hinge cover and disconnect the receptacle . This removes power from the freezer door . Use a butter knife between the dispensor grill and the lower portion of the dispensor cover , and press down and inward , forcing the bottom portion of the cover outward . Be careful due to theses are plastic retainers , built on to the dispensor cover . This pops the plastic cover pins off . Then lift the disp cover up to get past top retainer pins . Disconnect the plug from the dispensor cover . There are 2 screws holding the white housing , which need to be removed , and the housing will slide foreword , You should have access to the pin and spring .
wrong....ballpark..sorry
