When I tried to look behind it to see the problem, somehow the thing shorted out. Now the display is out and there is no power. I dropped the display down and looked behind it but I can't see any obvious problem. Any ideas?
You need a new one. Never try to take microwave ovens apart or look behind displays and into to the case.
https://www.fixya.com/support/r29874712-repairing_microwave_ovens
SOURCE: I have a KHMS 155
You have a shorting membrane keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There
should also be a "mini-manual" hidden inside the unit behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs, about $55-65 in this case.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
[email protected]
http://www.microwavedisplay.com
SOURCE: I need to rplace the bulb in the interior of the microwave. It's loose in the top housing.
some of the front(vent) covers have a sliding hook I think you need to push it to the left. You should be able to access the bulb when you get that off.
SOURCE: How do i replace the door handle
with most microwave ovens, for safety reasons... they are permanently sealed to prevent microwave leakage burns... i hope this helped you out..
SOURCE: KitchenAid KHMS 2050 SSS, doesn't
Hi asoleyma,
This error code F7 from a Ktchenaid oven means that the function key is stuck on ERC. This can be fixed by having the control board (also called ERC or clock) be replaced.You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. Just get your model number ready when you call.
Hope this helps.
Thank you for using FixYa.
