Vacuums Logo
Gail McNeely Posted on Oct 09, 2019
The silver tool catch button and spring popped off of my dc25 wand assemby. the catch button does not look broken, but i can not figure out how to load the spring and button back on the wand.
Megan
Level 1:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
Problem Solver:
  • Contributor 14 Answers
  • Posted on Oct 29, 2019
Megan
Contributor
Level 1:
Night Owl:
Problem Solver:
Answers
14
Questions
0
Helped
23909
Points
24
There should be a spot for the spring on the latch and a spot for the spring to sit on the actual wand. It should be held by two tabs on each side. Really they just pop on and off.
5 Related Answers
Anonymous
  • 83 Answers
  • Posted on Jul 30, 2009
SOURCE: Dyson DC-07 Hose Wand Spring Came Out. How to put back in?
You'll see that there is a round piece with a cross shape on the inside of the button wand release button - place the end of the spring over the cross - you'll see the same cross on the collar of the machine...it'll take some doing, but line the other end of the spring up with the cross and pop the button back into place - be sure to click it onto those two gray circular/oval shaped divets at the bottom where the release button connects to so that the button stays in place.
Anonymous
  • 458 Answers
  • Posted on Jan 02, 2010
SOURCE: extendable wand difficult to entend
try USE WD-40 (http://www.uline.com/images/en-us/transparent.gif ) to spray ....Wand Assy and Hose Assy.....
Anonymous
  • 10 Answers
  • Posted on May 13, 2010
SOURCE: The spring assembly popped out of the electric
replace wand
Anonymous
  • 957 Answers
  • Posted on Sep 25, 2011
SOURCE: The cyclone canister release catch
I would highly suggest to visit on your manufacturer's website or even contact them so that they provide a solution to your issue. Thanks.
small6363
  • 18429 Answers
  • Posted on Oct 01, 2012
SOURCE: dyson dc25 wand will not come out or go back into the machine
you need to untwist the hose go to the link below for instructions
http://www.youtube.com/watch?v=FJcNXrfQDVo
2answers
Dyson DC25 -wand extension lost a spring and becomes disconnected during use. I don't know where spring should be?
The button you push to release the wand has a spring to allow it to spring back after the button has been released. If that spring is missing the wand will not stay attached.
How do i install a replacement spring in a tool catch
it isn't obvious from the pics but if I had to guess u need to get both the catch and the spring (if u lost it) b/c the reason the spring came out is that the catch is already broken.
Once u get it, it simply pops into place.
look at this page - may help
http://www.vacpartswarehouse.com/Dyson-Silver-Tool-Catch-DC25-DC33-DC35-DC44-DC56-p/dy-911523-03.htm
I have a dyson dc25, it won't start. push the red start button but nothing. it won't stay down to start
The button is spring loaded so it will pop up and down everytime you press it. The button is fine if its springing.
1. Check Fuse
if machine does not switch on after checking fuse then there is an issue with either the cable or the motor.
1helpful
Dyson dc25 handle stuck at top of wand wont relaese
Hi there, it's Jack at Dyson.
A jammed DC25 wand may mean that the hose was twisted when the wand was last replaced on the machine. This can prevent the wand from extending or retracting fully. The video I've attached shows you the simplest way to resolve this.
If you would like any further advice from our experts, you can reach the Dyson Customer Helpline by calling 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Dyson DC25 head wont vacuum when pedalhas been pressed?
More then likely your valve lock assy has broken. if your looking at the back of the machine, to the outside of the ball you'll see a black arm/hook attached by a silver spring. it could be loose, broken or out of place.
If you need any help feel free to contact me.
Tim
TheVacCenter.com
1helpful
Dyson dc25 hose wont come off wand
tap it all round with the handle of screwdriver to loosen any dust that is stopping it from pressing in.
How do you put back plastic ring, half ring and spring back in dyson wand on dc25 animal
Hi Yvonne,
I'm sorry to hear you've had issues with your DC25 wand. It's probably best if you give our Helpline a call - if the wand has broken, we should be able to replace it under our 5-year guarantee, as long as the cleaner has been used in accordance with the terms and conditions listed in the user guide.
You can call us free on 0800 298 0298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
12helpful
2answers
Hose attachment
Your wand is getting stuck in the hose because the hose is twisted - you need to unwind it:
1) Pull the wand up as far as you can, all the way if possible
2) Stretch the hose out and unwind it, use some babypowder on the metal part of the wand and in the future, unwind and stretch the hose out after you use it
3) If you can't get the wand all the way out, remove the canister from the front, push the button where you see the 7 vertical grooves (on the opposite side of the hook that you wind the cable around) - then pull on the hook and pull the hose up and off of the machine - stretch the hose out from the bottom and pull the wand out - now apply baby powder to the metal rod and disconnect and stretch and unwind the hose every time after you used the wand to clean.
Top Vacuums Experts
AskDyson
AskDyson
Anonymous
Are you a Vacuum Expert? Answer questions, earn points and help others
