SOURCE: change blade
depending on how new the saw is there are only 2 ways to change out the blade. the older saws have a allen head screw that you must loosen or remove to take te blade off. this screw is located on the shaft at the top of the blade. shed some light on it and look for a slot above the guide.the screw will be either on the right side or the left side. Newer models will have a quick release on one side or the other,it will look like a little lever,you just flip it out with your thumb the old blade drops out then you install the new blade flip it back and your back in business.
SOURCE: Dewalt jigsaw (dw321) how to
UNPLUG TOOL. To remove the blade, lift the knob on the top of the jig saw approximately 1/4". Rotate the knob counterclockwise until the clamp is open (Figure 8a). Do not force the knob once it stops. Insert the blade as shown. Make sure the back edge of the blade fits into the support roller. Tighten clamp by turning top knob clockwise until you hear a click. Push knob down.
For "T" shank blades, insert blade to the shoulder of the shank.
Look at manual on the link below.
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/402086-01,DW321.pdf
Good luck please rate 4 thumbs up and please leave a testimonial
