SOURCE: ge advantium 120 microwave
It's pretty simple as long as you have an offset phillips
screwdriver...
Of course, be sure to disconnect power to microwave and be sure not
to touch the new halogen bulb with fingers.
STEP-BY-STEP:
First, remove upper vent panel and remove inner filter (same directions
for just replacing inner carbon filter):
Then, remove inner plastic grille (2 screws) and final screw on left
side of metal "air duct" - here's where you'll need the offset screw
driver (and a little patience!):
Then, you can gently lift the sheet metal panel, find the light
housing, squeeze and remove/replace :)
That's it...just replace bulb and reverse for reassembly. Be sure to keep track of screw locations there are various sizes/lengths used.
Doug
SOURCE: I recently purchased this home,
The manual is available on the GE web site
http://www.geappliances.com/service_and_support/literature/
Type in the model number
Good Luck.
SOURCE: GE Advantium 120 Microwave fan stays on, off only when door open
Looking at the schematic in the service manual here, I would say relay RY6 on the small sub PCB (relay board) has shorted contacts.
That's the relay that runs both the fan and turntable.
It's possible that it may be a bad connection or driving component on that board, but in my experience, it's virtually always a stuck relay.
The part number on the relay as shown in the photo is hard to read, but it looks like "OJ-SH-112LM".
I should have one of these or I can point you to one if you want to contact me with the exact number.
Feel free to contact me directly (and please remind me of your
full model number) for more information & help.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
William E. Miller
[email protected]
http://www.microwavedisplay.com
SOURCE: Light bulb in oven went out
Remove the top grill by removing two screws in the top. Pull the top of the grill out towards you as the bottom has pegs on it. About 6 inches from the left is metal cover that you just squeeze with your finger tips to remove. This exposes the bulb.
SOURCE: control panel "locked" on ge advantium 120
You might have set the child lock. Look in the manual. It is on P.36 in my manual.
